corner lights
corner lights
alright i have a problem with my corner lights on my eg hatch...when i put my lights on they dont work but if i put my blinker they do work ..whats the pproblem?
Re: corner lights (305accord)
both corner's or just one?
cuz i had that prob. once but it was only with one corner and when i changed the bulb it started working fine again. .
Re: corner lights ('94civic b16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’94civic b16 »</TD></TR><TR><TD CLASS="quote">its the way you have them wired, sounds like you wired them so they only blink with the turn signal.</TD></TR></TABLE>
huh? what the hell? why would he have to wire is corner lights for? they come already wired straight from the factory. read the post again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 305accord »</TD></TR><TR><TD CLASS="quote">alright i have a problem with my corner lights on my eg hatch...when i put my lights on they dont work but if i put my blinker they do work ..whats the pproblem?</TD></TR></TABLE>
OP, the question i have for you is, do you have anything tapped into your wires?
are your taillights out too?
305accord is a friend this is a little more info
He has them tapped into his sidemarkers but even before the sidemarkers his front coners never worked with the vehicles headlights on (2 clicks or the corners 1 click of the Headlight switch). All fuses are checked as well.
Re: (92EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EG8 »</TD></TR><TR><TD CLASS="quote">305accord is a friend this is a little more info
He has them tapped into his sidemarkers but even before the sidemarkers his front coners never worked with the vehicles headlights on (2 clicks or the corners 1 click of the Headlight switch). All fuses are checked as well.</TD></TR></TABLE>
if that's the case i would grab a voltage meter and start troubleshooting. can be a break in the wiring, a faulty relay, or the switch itself.
are the taillights operational?
Yeah its is the JDM way to have ur headlights like that but i like them when they are on. The tail lights as i said do work. Even hazards work in the back lights but not in the front
