Cursed with rare problems
Old Feb 6, 2007 | 12:11 AM
faSHOwidIT's Avatar
Default Cursed with rare problems
Last night i did a third gear pull and the car started to vibrate crazy from passenger side along with pulling to the right hard as hell. Cousin had the same problem due to axle, so i changed the pass. side axle. Still pulls hard to the right and vibrates crazy like as if something is loose. It all started to happen eversince i lowered my car. Keep in mind this is a 430hp motor. What the hell is going on? I'll raise the car back up tomarrow see if it still does it. keep me posted with ideas please!
Old Feb 6, 2007 | 05:06 AM
wilsel's Avatar
Default Re: Cursed with rare problems (faSHOwidIT)
could be a lot of things (mounts, tranny, wheel bearing, caliper sticking)
Old Feb 6, 2007 | 05:21 AM
BLUIZE256's Avatar
when you lowered the car did you make sure everything was tight and that you put everything on right?
Old Feb 6, 2007 | 01:20 PM
faSHOwidIT's Avatar
Default Re: Cursed with rare problems (wilsel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel &raquo;</TD></TR><TR><TD CLASS="quote">could be a lot of things (mounts, tranny, wheel bearing, caliper sticking)</TD></TR></TABLE> mounts are good, wheel bearings should be good since there's no play with the tires. also how can i tell if the calipers sticking and what would cause that? what comes to play with tranny also? and yes everythign was tightened. tripple checked.
Old Feb 6, 2007 | 01:26 PM
mike1114's Avatar
alignment?
Old Feb 6, 2007 | 05:14 PM
faSHOwidIT's Avatar
Default Re: Cursed with rare problems (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">alignment?</TD></TR></TABLE> how will a alignment cause it? it feels like as if something is coming out and popping out then when i slow down it wobbles back in to place. It takes like 5-10 seconds to wobble back in place.
Old Feb 6, 2007 | 05:21 PM
muhaMan's Avatar
wowww im havin the same problem...
i bought my car lowered and when i reach like 65 it starts to shake and vibrate alot..
Old Feb 6, 2007 | 05:27 PM
EG2Driver's Avatar
Default Re: (muhaMan)
how old are your ball joints? How are the boots?
Old Feb 6, 2007 | 11:25 PM
faSHOwidIT's Avatar
Default Re: (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">how old are your ball joints? How are the boots?</TD></TR></TABLE> i beleive they're still the ones that came with the car. How can you tell if the ball joints are going out?
Old Feb 6, 2007 | 11:35 PM
sal's Avatar
sal
Default Re: (faSHOwidIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faSHOwidIT &raquo;</TD></TR><TR><TD CLASS="quote"> i beleive they're still the ones that came with the car. How can you tell if the ball joints are going out?</TD></TR></TABLE>
Check if the boot on the ball joints are ripped.
Old Feb 6, 2007 | 11:43 PM
imburne's Avatar
216.244.10.111
A alignment would definately help. Do not rule it out. I had the same exact problem after lowering my car. I had a high horsepower turbo EG. So again, dont rule that out.
Old Feb 7, 2007 | 11:24 AM
faSHOwidIT's Avatar
Default Re: (sal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal &raquo;</TD></TR><TR><TD CLASS="quote">
Check if the boot on the ball joints are ripped.</TD></TR></TABLE> no they're not ripped.
Old Feb 12, 2007 | 09:40 PM
faSHOwidIT's Avatar
changed both axles, got an alignment, problem still here!
93egSLEEPER
Jan 4, 2008 03:45 PM
Sean @ ESG
Feb 18, 2007 09:12 AM
nateg
Oct 20, 2006 12:38 PM
skata89
Sep 1, 2006 08:05 PM
servion
Jul 7, 2003 07:06 AM
