new tires and already lumpy?????
Old Feb 6, 2007 | 12:09 AM
-Championship-'s Avatar
Default new tires and already lumpy?????
i bought the yokohama spec-2's just about a month ago, has about 85% tread
was doing a camber kit when i noticed on the driver side tire, i ran my hands on the inner side and felt lumps, sorta wavey, uneven?
a friend told me that the shock is no good, but i bought new shocks (tokico blues). and have about 10k miles on them..
was it because of the camber?...there is no toe in or out on them, oh and pressure is at 30psi
quick edit: forgot to mention that the tires are nosiy as hell!!!
Old Feb 6, 2007 | 12:39 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: new tires and already lumpy????? (CW_98gsr)
throw them through the window of discount tire
Old Feb 6, 2007 | 07:50 AM
DamnYank!'s Avatar
lumps on the sidewall? thats a tire issue, not a shock or alignment issue.
Old Feb 6, 2007 | 08:14 AM
onepoint-gsr's Avatar
Default Re: (DamnYank!)
If there is uneven wear on the tire then it could be alignment or your camber is causing premature wear. Also if its not constant wear on the inside, that its only worn on some parts on the inside of the tire then it could be a bent wheel. I would suggest taking them to a local reputable tire shop and have them look at them,rotate and re-balance them and see what you come up with.
Old Feb 6, 2007 | 08:47 AM
black_cap's Avatar
is it like a lump on the tire side wall? if so, these are usually caused by hitting a nasty pothole.
Old Feb 6, 2007 | 09:37 AM
r3v da t3g's Avatar
Default Re: (black_cap)
When your tires do that its called Cupping in the Tire Industry. I work at just tires and I get that alot. In any case there can be a few possibilities to your problem, Shocks are blown, usually that would cause bald spots not cupping, Tires are not balanced properly, Bent Rims, Alignment issues, or lastly Defective Tires. Take them back and have them back and have them check balance, and alignment.
Old Feb 6, 2007 | 09:39 AM
no not on the sidewall...its on the inside of the tire, where tires usually wear from camber issues...it has some wear because of camber and also lumpy. so it's my tire?...
Old Feb 6, 2007 | 09:48 AM
r3v da t3g's Avatar
Default Re: (CW_98gsr)
Camber is not the big of a deal unless you got some crazy camber, TOE is what causes premature tire wear the most. Go back to the shop and have them check out the balance and if they check the alignment. If anything I could probably help you out with these things if your willing to go to my work. But I only work on the weekends.
Old Feb 6, 2007 | 09:57 AM
Default Re: (r3v da t3g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3v da t3g &raquo;</TD></TR><TR><TD CLASS="quote">Camber is not the big of a deal unless you got some crazy camber, TOE is what causes premature tire wear the most. Go back to the shop and have them check out the balance and if they check the alignment. If anything I could probably help you out with these things if your willing to go to my work. But I only work on the weekends.</TD></TR></TABLE>
that would be cool man thanks, but i need to take care of this today, so im going to do an alignment, how much would be a good price for alignment?..
Old Feb 6, 2007 | 12:07 PM
r3v da t3g's Avatar
You can go to SEARS or somewhere and get LIFE TIME Alignment for like 100 something. Alignments are expensive already as it is, so i think life time would be worth the money if you get a mechanic that knows his ****. So....
100 ish for lifetime or 60-80 for regular depending on the place you go.
Old Feb 6, 2007 | 01:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3v da t3g &raquo;</TD></TR><TR><TD CLASS="quote">You can go to SEARS or somewhere and get LIFE TIME Alignment for like 100 something. Alignments are expensive already as it is, so i think life time would be worth the money if you get a mechanic that knows his ****. So....
100 ish for lifetime or 60-80 for regular depending on the place you go.</TD></TR></TABLE>
I went to this one place not too far from here and they are charging me 75 for all 4
hillbillycivic
Suspension & Brakes
11
Nov 3, 2012 06:37 AM
beanbag
Apr 5, 2009 09:55 PM
kcem1
Suspension & Brakes
Dec 15, 2005 01:48 PM
slowacura
Mar 12, 2004 05:14 PM
Rain_man
Jul 15, 2001 02:12 PM
