delsol vtec rear sway onto '00 civic hatch... does it bolt up?
Old Feb 5, 2007 | 07:19 PM
fireant's Avatar
Default delsol vtec rear sway onto '00 civic hatch... does it bolt up?
I'm trying to find the easiest path to a rear sway bar on my daily-driven (aka never raced) 2000 civic hatch. So NO I'm not looking to spend alot or get something in the 22mm range.. just a little improvement over stock will be fine.
Aside from getting some lock nuts for the endlinks, would the delsol vtec rear bar and bracketry bolt right on to the civic DX? Would the Si rear bar be the better choice?
Old Feb 5, 2007 | 07:23 PM
BlueIntegraBoy's Avatar
Default Re: delsol vtec rear sway onto '00 civic hatch... does it bolt up? (fireant)
The Del Sol VTEC 15mm rear sway will work, but you will need Si brackets and endlinks. If you can get an Si 13mm used with all the hardware, I'd go with that.
Old Feb 6, 2007 | 10:06 AM
fireant's Avatar
Default Re: delsol vtec rear sway onto '00 civic hatch... does it bolt up? (BlueIntegraBoy)
thanks!
8atman
70
Jul 6, 2006 04:19 PM
Nisif
16
Jan 24, 2006 07:53 PM
jdmstreethatch
Nov 11, 2004 12:20 PM
sol2nr
10
Feb 17, 2004 06:29 PM
TaboR
Dec 5, 2001 10:02 AM
