HELP!! EXEDY STAGE 1 CLUTCH KIT INSTALL
I am in the process of installing a stage 1 clutch kit into a 95 Integra ls, my question is this, on the ls flywheel there is about an 1/8" step sticking off the flywheel where the clutch disc meets to the flywheel. when i put the disc on and then try putting the pressure plate on it is about the same 1/8" gap between the flywheel and the pressure plate, I am sure the pressure plate is lined up to the correct position, all 3 alignment pins are in place the disc is just holding the plate from flushing up to the flywheel. Any ideas? Sound like they gave me the wrong clutch? Any ideas would be much appreciated.
methanemotorworks
Feb 13, 2006 07:32 PM
jaydeemmmm
May 10, 2005 11:54 PM
