after valve adjustment how to retorque the crankshaft?
He's correct. If you simply adjusted your valves there is no need to retorque the crankshaft bolt (since you never took it off to begin with and its still probably under the insane pressure like 600 ft/lbs +). You should be fine...........so long as the clanking went away after you adjusted the valves.
nutball72
May 13, 2006 04:14 PM
