obd2b to obd2a question??? easiest way to swap out a obd2b(searched for days)
Old Feb 5, 2007 | 01:46 PM
ricekiller1's Avatar
Default obd2b to obd2a question??? easiest way to swap out a obd2b(searched for days)
well i have a 00 civic coupe plannin an ITR swap. but in my research i see that with the 98 spec ITR you run into the imobleizer and larger ??32?? mm axle problems and its more $$$. this makes me kinda think the obd2a might be easier...which means ill have to get the obd2b to obd2a jumper harness.....now with this harness will i be able to pass emmisions? will i have any cel's? in the long run which way is the easier way to go? i know there are a lot of topics close to this but not specific enough for me... thanks for any help
Old Feb 5, 2007 | 03:07 PM
Default Re: obd2b to obd2a question??? easiest way to swap out a obd2b(searched for days) (ricekiller1)
up
Old Feb 6, 2007 | 03:25 AM
ricekiller1
Feb 6, 2007 06:35 AM
QuangAlang
Nov 2, 2006 02:11 PM
weak16teg
Sep 1, 2004 09:58 AM
F22B-EF
Apr 9, 2002 06:44 AM
