quick confirmation on head for LS whether its the good one or not.
Old Feb 5, 2007 | 11:17 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default quick confirmation on head for LS whether its the good one or not.
I've got a b18a1 from a 91 LS in my EG right now.
we JUST got in a wrecked 90-93 LS automatic yesterday.
It's build date is 10/91 and when I got the hood pryed open, It has gray plugs for the wiring harness.
I'm assuming this is an early 1992 obd1 b18a1 engine based on the plug color and build date.
my question is whether this has the head with the larger cams/valves in it as opposed to my 91 b18??
I would "assume" it does with it being obd1 but with such an early build date it makes me wonder if it's not using one of the leftover earlier heads....
is there any identifying marks on the 92-93 heads that can separate it from a 90-91 head??
oh and correct me if I'm wrong but I think the HP levels on the LS engines are:
90-91 = 130hp
92-93 = 140hp
94+ = 142hp
Old Feb 5, 2007 | 07:45 PM
HmgLauj69's Avatar
Default Re: quick confirmation on head for LS whether its the good one or not. (stackz)
there's four dots imprinted on the head above of the exhaust mani. one of them has the year of the head.
i think the cams specs are all the same between the years, it's the ports that are different. one way to tell is to look up the part numbers for the cams shafts and compare them. but im to lazy to do that
edit *new info
STOCK B18A
Intake Cam -
opens at -21.0 ATDC
closes at 31.0 ABDC
Exhaust Cam -
opens at 33.0 BBDC
closes at -19.0 BTDC
Lobe separation 116 deg.
Duration at .050" lobe lift
intake: 190 deg .225
exhaust: 194 deg .221
STOCK B18B
Intake Cam -
opens at -16.5 ATDC
closes at 23.5 ABDC
Exhaust Cam -
opens at 33.0 BBDC
closes at -23.0 BTDC
Lobe separation 114 deg.
intake: 187 deg .225
exhaust: 190 deg .225
Modified by HmgLauj69 at 9:28 PM 2/5/2007
vtec killin
Jun 26, 2007 12:06 PM
Mordeki
Sep 22, 2004 08:23 AM
B20b4door
Aug 16, 2004 05:10 PM
jdmeg18
Sep 30, 2003 05:20 PM
Ignitecivic
Jun 11, 2003 08:56 AM
