Look what showed up today =)
Old Feb 5, 2007 | 09:20 AM
JokerX-1.6T's Avatar
Default Look what showed up today =)
Well I finally decided not to go dohc zc and instead went with a nice dirty d15b wasnt to bad 650$ local and delivered to my house with p08 ecu. I could have saved 50$ and picked it up but I said screw it 600$ I waste my time and gas or 650$ I sit at home and nice and cozy so I chose the second option .<U> I know this is nothing new around here just thought Id post it</U>. Ill be ordering the complete harness and obd0 to obd1 coversion from rywire, as I am just way to lazy to have to run wires I just want to get it in the crx I figured I could work and do it myself or be lazy and wait for the mail so once again I chose the second option hopefully I will get the harness ordered up this week. I gotta do all the normal stuff to the engine anyway all new gaskets and seals all the way around and other misc stuff as anyone would do and throw some new bearings in the si trans I am gonna use. I guess Ill keep the old DX 1.5 with 210k on it as it still runs perfectly
Like I said not a big deal just wanted to throw it out there
Old Feb 5, 2007 | 09:43 AM
wiZCo's Avatar
Stouts 'n' Scotch
Clean and paint that thing. GL on the build.
Old Feb 5, 2007 | 09:46 AM
HBK's Avatar
HBK
Default Re: (wiZCo)
nice dirty d. I think thats got better aftermarket and swap potential over the dohc ZC, even though I love that motor too. Good luck with the swap, and watch out for that bitch pin
Old Feb 5, 2007 | 09:53 AM
crxnj's Avatar
Default Re: (HBK)
i used to hate on this motor but i love it now,,its like a sohc b16 with more tq. it revs and revs
Old Feb 5, 2007 | 09:54 AM
menoSi's Avatar
Default Re: (HBK)
wat are your plans with the car?
Old Feb 5, 2007 | 10:57 AM
joethejoeman's Avatar
Default Re: (menoSi)
looks like ur going to have some fun planned for this week
Old Feb 5, 2007 | 12:34 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (joethejoeman)
Wise choice getting an si trans for it. You'll have fun with it. Don't be afraid of the rev limiter.
Old Feb 5, 2007 | 12:59 PM
I just want to get it looking new again as much as I can this is my daily driver - I just recently put a si trans on my dx and with new oem upper control arms inner and outer tie rods new lower ball joints and new sway bar bushings. I spent a good amount of time replacing the interior pieces with pieces that were in better shape, and the rear pax wheel well had the good old honda rust so I have a patch panel to get welded in. I will be picking up the usual I/H/E and some konis with gc's and get a new coat of factory color paint - then back to dumping money into my 2000 civic
some pics of the car after I got it cleaned up and have since replaced the driver seat with one with no holes
https://honda-tech.com/zerothread?id=1684463
Modified by JokerX-1.6T at 5:39 PM 2/5/2007
Old Feb 5, 2007 | 01:35 PM
4dOoR-Ex's Avatar
i got a d15b but my cover wasent black.. it had a silver any diff?
Old Feb 5, 2007 | 01:36 PM
ILcrxsi1's Avatar
Default Re: (4dOoR-Ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dOoR-Ex &raquo;</TD></TR><TR><TD CLASS="quote">i got a d15b but my cover wasent black.. it had a silver any diff?</TD></TR></TABLE>no it's the same thing. different years came with the different valve cover. you have one of the newer ones
Old Feb 5, 2007 | 04:10 PM
aRedSoxFanANDaCRXowner's Avatar
NICE, good luck with your car.
Old Feb 5, 2007 | 04:56 PM
IndySporty's Avatar
Ahhh good old brakleen in the background, Honda Man's best friend
Old Feb 5, 2007 | 05:10 PM
Crx Jimmy's Avatar
Default Re: (IndySporty)
I see your valve cover os marked A-T im guessing its from an A utomatic T ransmission? if so are the cams the same? I know the b series cams are wussy on the auto motors
Old Feb 5, 2007 | 05:14 PM
ILcrxsi1's Avatar
Default Re: (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I see your valve cover os marked A-T im guessing its from an A utomatic T ransmission? if so are the cams the same? I know the b series cams are wussy on the auto motors</TD></TR></TABLE>good question
Old Feb 5, 2007 | 05:22 PM
KillSwitch's Avatar
Default Re: (ILcrxsi1)
your crx is ******* clean dude!
Old Feb 5, 2007 | 05:36 PM
ilovemyb16a's Avatar
Default Re: (KillSwitch)
i have that smae motor in my daily beater but it its not that fast is it because im running a p28 and not the po8 and what can i rev that motor to
Old Feb 5, 2007 | 05:55 PM
ILcrxsi1's Avatar
Default Re: (ilovemyb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyb16a &raquo;</TD></TR><TR><TD CLASS="quote">i have that smae motor in my daily beater but it its not that fast is it because im running a p28 and not the po8 and what can i rev that motor to</TD></TR></TABLE>stock redline is 7200 rpm. I usually don't take it past that but sometimes I'll hit the 7800 rpm rev limiter and it doesn't bother the motor at all.
Old Feb 5, 2007 | 06:38 PM
RockinthEFhatch's Avatar
Default Re: (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">its like a sohc b16 with more tq. it revs and revs</TD></TR></TABLE>
What? Is there such a thing?
Old Feb 5, 2007 | 06:44 PM
ILcrxsi1's Avatar
Default Re: (RockinthEFhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch &raquo;</TD></TR><TR><TD CLASS="quote">
What? Is there such a thing?</TD></TR></TABLE>he's just saying it likes to rev. Plainfield
Old Feb 5, 2007 | 06:47 PM
C_R_X_V_T_E_C's Avatar
I could hit 7800 on my D15B all day, not a problem in the world......... Good Luck Man, AND to the best of my knowledge the AUTO and the MANUAL D15's are the same....
Old Feb 5, 2007 | 07:19 PM
jdmd-series's Avatar
Default Re: Look what showed up today =) (JokerX-1.6T)
thats weird i bought a crx with the same motor and it is obd1
Old Feb 5, 2007 | 07:20 PM
Deetz's Avatar
Crazy Honda Guy
Good luck on the swap! You'll have fun with the new motor.
I saw the pics of your crx, looks awesome so far!!
Old Feb 5, 2007 | 07:22 PM
allsho's Avatar
damn lucky!
the past days/few hrs ive been doin a dpfi d15b7 swap! Im jelous!
Old Feb 5, 2007 | 08:09 PM
crxforum's Avatar
Default Re: (allsho)
You have PM.
CRX Forum
Old Feb 6, 2007 | 06:22 PM
Default Re: (crxforum)
well if i wer to buy a chip for my d15b how high can i pull it 8500 or is that too much
