resonation / vibration
Old Feb 5, 2007 | 05:15 AM
R boi UK's Avatar
Default resonation / vibration
hey guys a quick question,
aimed people running mugen stuff
my car came with a mugen 4-1 and twin loop but still has its cat on
ive noticed at part throttle, normal driving and between 2- 3.5k revs right in the normal driving band im gettin what i can only describe as resonation or a rattle, ive looked at al the heat sheats im im pretty sure its not that and i dont think its coming from the exhaust
im pretty sure its coming from the manifold and its a characteristic of the mugen one, its def coming from the front of the car in the engine day but it also cant be heard from outside the car
its only does its as partial revs but its annyoing the hell out of me. does anyone have any ideas besides the heatshield
also anyone with a mugen header experience the same thing??
Old Feb 5, 2007 | 11:01 AM
vtec.dc2's Avatar
Default Re: resonation / vibration (R boi UK)
here are all the possible reasons why exhaust parts would rattle:
a) its hitting agains something, like frame/bumper or other car part
b) bolts are loose
c) cracks
d) loose material inside resonators/mufflers cats
reason for why it would sound like ****:
e) you're running a motorcycle muffler on a 4 cylinder
f) you have an exhaust leak
causes and solutions:
a) if its hitting body parts, you may fix it by playing around with hangers, in worst case exhaust itself may need to be cut or hangers rewelded. if exhaust part is near the engine and its hitting a non moving part, it may lead to failure of that part like cracks.. etc
b) loose bolts will certaintly lead to rattle and exhaust leak
c) if your heatshield is cracked right around the bolt area, it will rattle, sometimes its kind of hard to notice
d) often double wall piping will have loose material in between like oem header leaving with constant rattle at random rpm, cats going bad will do the same and anything trapped between heatshields
Old Feb 5, 2007 | 11:48 AM
Big Phat R's Avatar
Hello,
I had the same problem with my Mugen 4-1 and my Spoon 4-2-1.
It is an inherent resonance of the exhaust pulses of the B18 that you cannot get rid of.
I even called King Motorsports about it and they said it's normal.
You just have to live with it.
Interestingly - I when I put the stock cast manifold back on - I could still hear the resonance - but it was much much quieter.
I have a Hytech header now - and I don't hear that buzzing as much - I'm not sure but I think the anti-reversion cones inside the header help eliminate it.
cheetoh
Jan 6, 2019 12:37 PM
CaliforniaSi
Jun 8, 2012 02:12 AM
JdmLude04
Honda S2000
13
Oct 15, 2004 04:37 PM
LostLude
Jan 17, 2003 06:18 PM
CPR
Jul 10, 2002 08:38 AM
