b18c1 assemly
Old Feb 4, 2007 | 09:02 PM
poppypizza's Avatar
Default b18c1 assemly
got a block in parts need a little help some pics of where all the bearings and girdle goes how to take crank out stuff like that.. thanks!
Old Feb 4, 2007 | 11:47 PM
ExospeedAMcrx's Avatar
Default Re: b18c1 assemly (poppypizza)
you need to put it back together?
Old Feb 4, 2007 | 11:51 PM
integrainside's Avatar
Are you serious? If your that lost try paying someone else to do it. If you go to Autozone and just get a Haynes or Chiltons repair manual it will tell you everything you need to know. You cant build a motor from lookin at pictures, lol
Old Feb 4, 2007 | 11:55 PM
Default Re: b18c1 assemly (exospeedAMcrx)
if you are putting the block back together, there are MANY things that have to be checked before putting stuff back on the block.
1. Rod and main Bearings have to be measured to spec.
2. Each bolt has to be torqued down to the specified specs(check the Honda book. chiltons or haynes for that)
3. If putting different pistons in the block, you should check the condition of the cylinder wall sleeves and piston to wall clearances.
There's so much that can go wrong with putting a block back together. Even proper builds can have problems, what more if you didnt check and measure all the steps above. You'll be in deep sh*t.
Old Feb 5, 2007 | 08:14 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">... check the Honda book. chiltons or haynes for that...</TD></TR></TABLE>You're in deep enough that you should get the real thing.
Go to http://www.helminc.com for the best book about assembling the engine.
Omegax10
Mar 31, 2012 12:11 AM
Bense
Jun 17, 2006 05:40 PM
phyzJunkieCivic
Mar 4, 2006 05:13 PM
preludesi93-arg
Jun 23, 2005 10:46 AM
BodyKits NW
Mar 17, 2005 01:58 PM
