Help- Broke off bolts holding on Distributer cap
Yes
i sprayed them with wd 40
let them sit for about 3 hours,
then went to take them off all 3 broke
when the first one broke i thought i was alright and would be able to remove the bolts with vise hoping some would be exposed behind the cap,
sure enough they broke off inside
Any ideas?
Thank you very much for your time
Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si »</TD></TR><TR><TD CLASS="quote">pull the dizzy off, get a really small drill bit and take your time drilling them out...</TD></TR></TABLE>
yeah thats pretty much all u can do man!! just take ur time.. get a small enough drill bit as well!
Screw drilling them out.
The same thing happened to me.
Use a damn needle nose plier and grab the end of the bolt where it comes through the other side (yes, it should poke through enough to grab it) and give it some rotations until you can unscrew it the same way you screwed it in.
I did it w/ the dizzy in the car, so it's definitely possible, but if you can't get leverage or access to the bottom bolt - simply take it off (don't forget to replace the O ring).
.I did it w/ the dizzy in the car, so it's definitely possible, but if you can't get leverage or access to the bottom bolt - simply take it off (don't forget to replace the O ring).
Same thing happened to me once, I notched it with a dremmel and used a small flathead to screw it out the other end coz there there wasnt enough thread on the other end to grab with needle nose pliers...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim »</TD></TR><TR><TD CLASS="quote">Same thing happened to me once, I notched it with a dremmel and used a small flathead to screw it out the other end coz there there wasnt enough thread on the other end to grab with needle nose pliers...
Weird ****, mine did and I had the regular bolts that came with it...
I replaced it with some stainless steel ones for like $.75 piece, but it was well spent IMO.
</TD></TR></TABLE>Weird ****, mine did and I had the regular bolts that came with it...
Yeah i drilled them out and used a tap
all is well
Thanks guys
Tried to start car and went, sttttttttttttttttttttt
forgot to plug in dizzy
MY bolts were too short like .1mm was exposed,
so i tried vise and nothing could grip it
all is well
Thanks guys
Jameson
Jan 20, 2007 07:55 PM
