Steering wheel shaking while punching gas...
Old Feb 4, 2007 | 05:54 PM
VIS250P's Avatar
Default Steering wheel shaking while punching gas...
I installed a pair of new CV axles, and the new hub/hub bearing on the driver side.. The problem is the lower ball joint boot torn on the driver side and Im not sure is that a problem of the steering wheel shaking.. Here is the pic of the ball joint:
PS The tires were mounted and balance..
Old Feb 4, 2007 | 06:09 PM
Arsenal's Avatar
Default Re: Steering wheel shaking while punching gas... (py)
What axles are they?
Chances are if they are auto zone or something like that then the axles are not balanced properly.
Old Feb 4, 2007 | 06:23 PM
VIS250P's Avatar
Default Re: Steering wheel shaking while punching gas... (Arsenal)
I bought them from Advanced Autopart..
Old Feb 4, 2007 | 06:34 PM
Brick Top's Avatar
my guess of the shaking only when accelerating would be the axles. install go ok? are they in all the way? and if your ball joint boot is bad, i would replace it. not saying thats causing the shaking.
Old Feb 4, 2007 | 06:42 PM
Kenso's Avatar
HT White Ops
Default Re: Steering wheel shaking while punching gas... (brick top)
Axles. Or more specifically the inner joints (assuming the axles are seated completely, etc.). A lot of aftermarket axles are poor quality. If your budget allows, go for the OEM remans from Acura. Otherwise, someone else here may be able to suggest an aftermarket source they've had good results with.
Old Feb 4, 2007 | 06:51 PM
GO-FIGHT-KILL's Avatar
OEM =
I've had nothing buy problems with every Advance Autoparts CV axle I've used... Installed a pair in my '94 Civic, and they shook like you described.
Do you still have your stock axles? I'd recommend getting them rebuilt. Runs about $30 a piece at the local place in town.
Old Feb 4, 2007 | 07:03 PM
NorthernXposure's Avatar
Default Re: (GO-FIGHT-KILL)
i had the same problem... change out the axle where the shaking was coming from and eliminated the problem
Old Feb 4, 2007 | 07:36 PM
Arsenal's Avatar
Default Re: Steering wheel shaking while punching gas... (Kenso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kenso &raquo;</TD></TR><TR><TD CLASS="quote">Axles. Or more specifically the inner joints (assuming the axles are seated completely, etc.). A lot of aftermarket axles are poor quality. If your budget allows, go for the OEM remans from Acura. Otherwise, someone else here may be able to suggest an aftermarket source they've had good results with.</TD></TR></TABLE>
Raxles.com
Have had excellent service with them. About to order another set tomorrow for another car.
The product is vastly superior to the cheap remans. No problems what-so-ever.
Old Feb 4, 2007 | 10:05 PM
VIS250P's Avatar
Thanks, I want to get the OEM axle to rebuild but I have trouble taking the CV axle off the Spindle arm. It took me 7 hours take it off because it had rusty.. But the outer CV joint has a mushroom cuz I hit them with 5 ton hammer.. I thought they cant get them rebuild and that's why I throw them away in trash...
Old Feb 5, 2007 | 07:53 AM
ericlee303's Avatar
I'm having the same problem too accellerating from low speeds, and I'm pretty sure it's the axles, because it does it with whatever wheels I put on it.
Old Feb 5, 2007 | 08:37 AM
Shalom's Avatar
py you should seriously listen to what everyone has been saying. Raising your car from stunna slizzammed ride height will alleviate a lot of your suspension problems. Especially because you're posting a lot more frequently about odd wear issues, rubbing, rapid part failures etc, and dont really sound like you know what you're doing anyway.
petr0lb0mb
Transmission & Drivetrain
15
Sep 19, 2018 09:06 PM
TEGGRY
Sep 5, 2007 09:47 AM
zach1288
Jan 15, 2007 06:32 PM
JDM H22
Dec 13, 2005 09:47 AM
ghettols
Aug 22, 2003 11:57 AM
