75w-140 tranny oil
Old Feb 4, 2007 | 03:49 PM
xlusiveracer's Avatar
Default 75w-140 tranny oil
i was wondering if its ok if i used this type of tranny oil on my b16 s1 tranny.its the supertech kind from walmart.
Old Feb 4, 2007 | 03:52 PM
Redline130's Avatar
Default Re: 75w-140 tranny oil (xlusiveracer)
No, that's way too heavy for a Honda tranny. 10W-30 is what you should use.
Old Feb 4, 2007 | 03:56 PM
Default Re: 75w-140 tranny oil (Redline130)
yah thought so.sorry im new to tranny fluids.10w-30 as in motor oil? or tranny oil?
Old Feb 4, 2007 | 04:00 PM
Redline130's Avatar
Sorry, motor oil. Or if you want, you can go to your local Honda dealer and get OEM manual tranny fluid...it's just a little more costly than 10W-30. Either one will work fine.
Old Feb 4, 2007 | 04:39 PM
Crx Jimmy's Avatar
Use honda MTF only, if you need to top it off its 10w-40 not 10-30 like posted earlier
Old Feb 4, 2007 | 07:13 PM
SOHCwarrior's Avatar
Default Re: 75w-140 tranny oil (Crx Jimmy)
mobil1 10w30 works good and GM syncromesh is great, especially if you need to get rid of some grinds.
I've never used honda mtf and never had a problem
Old Feb 4, 2007 | 08:36 PM
superhatchbackbros's Avatar
syncromesh FTW!
Old Feb 4, 2007 | 09:50 PM
liquidoblivion's Avatar
manual calls for 10-30 not 10-40, don't use mobile 1 you don't want to use a synthetic too slick for the blocking rings. Use a plain 10-30 dino or honda MTF.
Old Feb 4, 2007 | 09:59 PM
.Manny.'s Avatar
Touching My Member
Default Re: 75w-140 tranny oil (liquidoblivion)
i havent seen any problems with 10w-30, but, go to honda and get the manual transmission fluid. its made for it, stick to that
Old Feb 4, 2007 | 11:29 PM
Dave_Darling's Avatar
Default Re: 75w-140 tranny oil (90_EF_Si)
Actually, the transmission is made for motor oil. Check the owner's manual if you don't believe me...
--DD
Old Feb 5, 2007 | 09:10 AM
Default Re: 75w-140 tranny oil (Dave_Darling)
so is it bad to use full synthetic for my tranny? because yesterday i just did a tranny flush and thats what i added.
Old Feb 5, 2007 | 09:15 AM
nappyroots827's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xlusiveracer &raquo;</TD></TR><TR><TD CLASS="quote">so is it bad to use full synthetic for my tranny? because yesterday i just did a tranny flush and thats what i added.</TD></TR></TABLE>
yeah, its too thin, doesn't offer good protection and it'll probably leak through your seals
Old Feb 5, 2007 | 10:08 AM
crxnj's Avatar
Default Re: 75w-140 tranny oil (nappyroots827)
synthetic seems like it would shorten the life of the syncros..
10w30,10w40,5w30 regular oil all works fine. honda mtf works fine,pennzoil snycromesh works for covering up grinds (not fixing).
Old Feb 5, 2007 | 01:16 PM
Jerzey Rex's Avatar
Default Re: 75w-140 tranny oil (mr.speaker)
just get gm syncromesh and you'll be fine...i had a hard 3rd gear grind and after 500 miles of driving it disappeared...it aint cheap but it does a hella job
Old Feb 5, 2007 | 01:38 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: 75w-140 tranny oil (Jerzey Rex)
The dude at my local honda dealership told me that honda MTF is nothing more than 5w30.
Old Feb 5, 2007 | 02:22 PM
janz3n's Avatar
Default Re: 75w-140 tranny oil (ILcrxsi1)
lol why would you go out and buy honda mtf? do you like spending more money for the same thing as regular oil?
Old Feb 5, 2007 | 02:27 PM
ILcrxsi1's Avatar
Default Re: 75w-140 tranny oil (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">lol why would you go out and buy honda mtf? do you like spending more money for the same thing as regular oil?</TD></TR></TABLE>Because I was listening to the hype on here about honda MTF. And then the dude there was like "you know this is just 5w30? you don't have to spend $6 a quart on this stuff when you can just go buy 5w30 anywhere."
Old Feb 5, 2007 | 03:42 PM
88 rex's Avatar
&lt;---Sees no reason why Synthetic would hurt.
I do use Pennzoil synchromesh though. Same as GM synchromesh. Also, used Honda MTF. Didn't notice any difference, but neither hurts.
Old Feb 5, 2007 | 05:28 PM
Crx Jimmy's Avatar
Default Re: 75w-140 tranny oil (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">you don't have to spend $6 a quart on this stuff when you can just go buy 5w30 anywhere."</TD></TR></TABLE>
I don't know where you guys buy MTF for 6 a quart? its like three dollars at my honda dealer. It is NOT the same as motor oil just smell it, it reeks like gear oil, it has gear oil properties that are not found in motor oil. motor oil is for motors gear oil if for gears My manual for my b18 states to use 10-40 if honda MTF is not available and to use it to top it off, maybe d series are different and you are using a guideline from 17 years ago. honda has superseded it with MTF. if your manual does state motor oil, why do you think that is? why would honda go through the trouble of creating a new fluid if there weren't problems with the old fluid? regular oil is at least $2 a quart, for an extra dollar a quart I think I'll use what recommended. go into the dealer and ask for oil for your manual transmission and see what they hand you, I bet it wont be a quart of motor oil.
Old Feb 5, 2007 | 05:57 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>msrp is only "suggested" retail price. stealerships can charge whatever they want.
steezychristian
Sep 22, 2011 03:37 PM
meagainsttheworld
40
Sep 5, 2006 02:52 PM
Johnny_Rocket
Oct 8, 2005 04:34 AM
Brian-Brian
Oct 16, 2003 03:46 AM
mickey513
May 6, 2002 11:45 AM
