collector angles
Old Feb 4, 2007 | 03:28 PM
Sobe_Death's Avatar
Default collector angles
So I have been trying to set up a jig to cut a 4-1 merge collector using 1.5 inch pipe for an SAE project. I set it up so that it would cut at a 15 degree angle, and I was able to rotate the pipe exactly 90 degreesin the jig to make the second cut. I practiced on pvc first, however I cannot get the merge to meet up well in the center. each cut is ~5-10 degrees off in the center. When I adjust for this, the outlet diameter becomes very small but the centers meet up.
What am I doing wrong? I have gone through about 10 feet of pvc trying to figure this out!
SideFX
Aug 4, 2011 12:13 PM
importboi22
Southern California
11
Sep 24, 2009 10:12 AM
DMax013
Welding / Fabrication
10
Feb 18, 2005 10:18 PM
