Newby Here
Hey Guys whats up, i just bought my first Honda
a 90 crx si with a dohc zc, and was just wondering wat type of goodies i can buy for under the hood, till i can afford to go bigger??
any tips or any help is greatfull!!!!!
You can start with the basics, air intake, header, and a cat-back exhaust system, if the car doesn't already have some or all of those parts. The big question is, how much do/can you budget to spend on the car?
as a few guys told me in myt post aobut what to do with some extra money , check everything hoses, belts, lines , check for leaks anywhere and get any and all maintenance done first , bettr to have a slower car running perfect than having a fast car running like crap
what are you getting the b16 ready for? i dont know if i misunderstood you want to have it boosted when you put it in, or further down the road. either way id swap it in already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR-Rex »</TD></TR><TR><TD CLASS="quote">Hey Guys whats up, i just bought my first Honda
any tips or any help is greatfull!!!!!</TD></TR></TABLE>
really nothing besides forced induction..everything else is a waste of money,,cam gears,fuel rail and regulator,spark plug wires and msd igntion,,all that **** is a waste of money and will make your car look fast but not be fast....
you say you have suspension already? is it good or some bullshit? if its bullshit you should listen to sired91 and do that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veritasaequatis »</TD></TR><TR><TD CLASS="quote">to bad you're in ca i could use that swap</TD></TR></TABLE>
I can ship the head and cams. $750 shipped.
Hows your clutch? You could get a stronger clutch and a lighter flywheel for right around 700. A fresh clutch can make a huge difference if the one you have is stock or worn out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">
you say you have suspension already? is it good or some bullshit? if its bullshit you should listen to sired91 and do that</TD></TR></TABLE>
Im sorry, I didn't see where you posted you already have suspension? Are we blind?
Is the "suspension" you speak of just shitty e-gay springs and crap struts or cut springs or what? Invest in a QUALITY suspension. This will make a slow car eat a fast car with the right driver.
700 dollars will get you NOTHING in performance that will make you notice the difference unless you throw some nitrous on it, and then you will blow your motor because you wont be tuned or built for it.
So......give us more details or nothing will help your car.
Cams and gears will do nothing for you at this point. Neither will intake or whatever aftermarket ignition you get UNTIL you build the **** out of it or boost it.
so.....QUALITY SUSPENSION.
