Whats a SIGN of HID bulb going bad??? help!
Old Feb 4, 2007 | 12:52 PM
pushinlsteg's Avatar
Default Whats a SIGN of HID bulb going bad??? help!
my girlfriend has a 6000k HID kit on her car...some off the wall chinese or japanese brand.. they have lasted for about 1.5 years, one of them, the left has gone from a bright blueish/white to a purpleish color, its not really dim, it more or less just looks like a 8000k bulb or something, sometimes it looks like its flickering a little bitter, it turns on the same as the other bulb but when they start to fade and the right one holds at a bright white the other one fades to a purpleish color...
is it just the bulb that needs to be replaced or is it the ballast? I could troubleshoot but its 10 degree's outside and I was looking for a quick answer maybe someone has already encountered
thanks.
Old Feb 4, 2007 | 12:57 PM
TeH PLAYA's Avatar
Default Re:
Should be ok.. HID bulbs tend to get more color as they age.
Old Feb 4, 2007 | 01:24 PM
Default Re: Whats a SIGN of HID bulb going bad??? help! (pushinlsteg)
one of them is now purple the other is still whiteish blue that is somewhat annoying... do you think its just the bulbs?
Old Feb 5, 2007 | 02:32 AM
I looked on the ballast its guangtai lighting is the company...
anymore help on possible problem?
Old Feb 5, 2007 | 06:45 AM
Options's Avatar
All Secrets Known
Default Re: Re: (TeH PLAYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeH PLAYA &raquo;</TD></TR><TR><TD CLASS="quote">Should be ok.. HID bulbs tend to get more color as they age.</TD></TR></TABLE>
That's right. I had the same problem with my TSX projector retrofit. I bought some supposed new Philips bulbs on Ebay, and one was more blue than the other. I thought there was something wrong with the projector, so I switched the bulbs from one projector to the other and the problem was still there. I replaced both bulbs and now they are perfect.
The only solution is to get new bulbs.
Old Feb 5, 2007 | 12:07 PM
okay what brand bulbs can I go with and will they pretty much work with any set of ballast? I dont care if I need to rewire it...
Old Feb 5, 2007 | 12:13 PM
chitownrida's Avatar
when mines died it would flicker when powered on.. sometimes not turn on ...and be real dim.. took it out.. had kinda of a "salt" covering over the bulb.. it was dead
i just bought some techone replacements from ebay.. for like 80$.. so far so good
*knock on wood*
rainmanef
Lighting
Jul 10, 2008 05:26 PM
accord99power
Aug 4, 2007 05:19 AM
skingfreak
Jan 29, 2007 06:30 PM
parfait2882
Dec 14, 2006 09:04 AM
ThaReal24k
Apr 28, 2005 08:11 PM
