took my new car to the DRAG STRIP
ok...so this may not be the best, i just got my car (94 integra ls COMPLETELY STOCK) and i have been driving stick for about 24 hrs. and they had some highschools races so i went... and here are the times
R/T 1.034
60' 2.491
330 7.037
1/8 10.800
MPH 65.16
1000 14.044
1/4 16.778
MPH 82.49
R/T 1.034
60' 2.491
330 7.037
1/8 10.800
MPH 65.16
1000 14.044
1/4 16.778
MPH 82.49
What's the elevation up there? a 16.7 might be a respectable stock LS time if you're far above sea level. A guy I know ran a 16.6 here in Colorado in his LS w/intake, exhaust, and stripped interior. He's got a Type-R wannabe spoiler off a Cavalier, which is apparently pretty heavy (his hatch wont open/stay open without help), so I'm sure that's weighing him down a bit. But, I think that's a respectable time for up here. A stock Type-R ran a 15.9 at the very same track.
I raced him and won the other day, and without exactly shifting at optimal points either. He also still had his interior gutted, and I have full interior w/stuff in the trunk (I'll clean it out one of these days...). I was experimenting with different shift points; we were pretty even while I was shifting at 6.5k. I was actually aiming for 6.1k (optimal shift point for 3 of the 4 shifts, based on dyno of another LS w/ I/H/E), but I kept over doing it (trying to go by sound/feel, but I just installed header and exhaust). I decided to try redline, so I took 3rd up to 7k and pulled on him real good once I got above about 6k. But anyways, he ran a 16.6 so I'm thinking I could run a 16.5 or maybe 16.4 up here. That would be about mid 15's at sea level.
So, find out what most stock or lightly mod'ed LS'es run at that track and compare your times to those. 16.7 would be a bad time for sea level, but it isn't bad at all up here. It's all a matter of where you are.
that isent bad at all, first time wiht mine at the track alli could get was a 15.5...but like everboyd said lots of other things go into it, my problem was tires and the heat in FLA
my first time at the track
r/t 1.197
60' 2.349
330 6.527
1/8 9.999
mph 71.11
1000 12.996
1/4 15.537
mph 88.79 on a 96 rs with intake...
r/t 1.197
60' 2.349
330 6.527
1/8 9.999
mph 71.11
1000 12.996
1/4 15.537
im on street tires...took out my jake and spare,and that board behind the back seat.i dont like to brag,but yeah im a good driver...and i have max-speed coil overs slamed almost all the way,and a old k&n intake short ram..and thats it and my car has 70k if that helps at all....
and i had 1/4 tank of 87 gas
[Modified by rsr001, 8:07 AM 5/21/2002]
and i had 1/4 tank of 87 gas[Modified by rsr001, 8:07 AM 5/21/2002]
