EF to DA brake question
how can you tell if the integra is ABS? the integra is a RS with all wheel disc brakes, does it matter if the MC, brake booster, port valve is ABS?
I got a 91 CRX HF
I got a 91 CRX HF
prop valve is in a differant location on the abs DAs and isnt easily accessible. the rest are in the same old place and are the same proportion values.
ok so I can use all ABS stuff execpt the porp valve? and isnt the ABS porp valve on the left side of the engine bay? or is that non abs? cause Im not sure if his car is ABS or not
JimmyAtlantis
Dec 8, 2005 10:38 AM
phantom_sol
Oct 5, 2003 10:22 AM
