installing high flow cat(any tips)
well the 3 bolts connecting the cat to the exaust has seized. hopefully my air tools can break them free. also whats the best way to remove the 2 oxygen sensors. i don't think there is enough room to use a wrench under the car to unscrew them. i will be doing this tomoorow
to remove seized stuff use liquid wrench, i used it and a large ratchet and i got them off. as for the O2 sensors...a bigass wrench i htink like 21 mm or something it was huge. just fit it under...
Pull the wires (fron the rubber grommet) down, there is more wire inside the car.. then un-clip it fron the connector and the 02 will come down with the CAT.
Remove it easily!
The one from the header can un-clip from the connector a little further up in the engine bay (follow the wires)
Remove it easily!
barker7
Sep 22, 2011 08:03 AM
jdmspoonitr
Nov 17, 2002 06:23 PM
.Chris.
Oct 7, 2002 02:42 PM
ekimmel
Apr 16, 2002 10:14 AM
