need a suspension mechanic to come to my house in OC. FAST
had my friend try to change out the suspension for coilovers and the damn driveshaft of the FIT came off. I can't get the damn thing back on and I now can't take the car to a shop to finish the work. I'm pissed and tired. Need help freakin fast. I have big 500 watt lights to work on at night or help me tomorrow. name your price!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehondaconnection »</TD></TR><TR><TD CLASS="quote">did you say it was a honda fit?maybe I can help.</TD></TR></TABLE>
yes honda fit
yes honda fit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screen_name »</TD></TR><TR><TD CLASS="quote">your axle came out?</TD></TR></TABLE>
driveshaft.
the thing between A and B in the diagram.
driveshaft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehondaconnection »</TD></TR><TR><TD CLASS="quote">What exactly is goin on?</TD></TR></TABLE>
the long black thing on the left isn't going all the back in so I can't get the hub straight to put the coilover back in
it should slide back in try n twist it as u put it in, also check for the little c-clip at the end, im assuming from the pic this is ur driver side axle/shaft. and it goes straight into the tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screen_name »</TD></TR><TR><TD CLASS="quote">basically, or so it seems, appearently not that easy since he says it wont go back in. give it a little loving and some lube just like a 18y/o girlie</TD></TR></TABLE>
haha.. but yea ive never had any problems puttin axles in..takin it out is another story
.. then again i never worked on a fit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcantu »</TD></TR><TR><TD CLASS="quote">
take your suspension knuckle where the two big bolts go through and slam it towards the trans.make sure the axle is in the trans a little before you do.if that doesnt work free the ball joints grab the whole hub and slam it in!Hook me up some free parts when your finished.
</TD></TR></TABLE>take your suspension knuckle where the two big bolts go through and slam it towards the trans.make sure the axle is in the trans a little before you do.if that doesnt work free the ball joints grab the whole hub and slam it in!Hook me up some free parts when your finished.
me either, no probs taking off of putting back on at all, but i did have problem breaking some before
but then again ive never worked on a fit either. can the OP be more specific? like does it go in at all? if it does try tapping it with a rubber mallet, making sure its not in gear, did u drain ur tranny oil? hmm i would help u out for free but im far as expletive.
hey guys,
I can get it in partially because i can tell when i turn the rotor the other wheel moves. it's the driver's side axle i guess. I found a international service manual online and it was called a driveshaft.
I was afraid to unbolt more stuff because i can imagine things even being worse.
i'm gonna try to slam the ****. it's just sucks ***** right now. the car is 1 month old.
thanks guys!!! i messed around w it. used a jack to get a better height and the **** popped out.
all you guys that chipped in, if you're ever in fountain valley stop by and I got a beer for ya or a shot of patron. your call.
Did you guys pull the axle out or something?... You guys might have pulled out the bearings inside the boot out of place.. in that case you'll have to open up the boot and realighn it
RichieCB7
Nov 17, 2004 03:39 PM
m0t0rhead
Jul 29, 2003 03:07 AM
