Axle Strength: approximate HP level for 90 STD HB axles?
Anyone know an approximate HP/TQ level (max) that can be maintained reliably with street tires (maybe even 100 treadwear autox tires)?
Modified by gwiffer at 1:47 PM 2/8/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap »</TD></TR><TR><TD CLASS="quote">I am going to say around 250-300hp maybe?</TD></TR></TABLE> for standard axles? i thought standard axles are like the hf and hollow. if so i wouldn't put much more than 200 max, reliably anyway.
Yes, standard axles, are they actually hollow vs solid (dx,si) or do they just have smaller splined sections and a lower spline count?
I had a pair of std axles on my old std civic with a sohc zc. They only lasted a month. I drove on them pretty hard. They were from autozone. They were fine the first couple weeks but both started clicking bad after that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy »</TD></TR><TR><TD CLASS="quote"> for standard axles? i thought standard axles are like the hf and hollow. if so i wouldn't put much more than 200 max, reliably anyway.</TD></TR></TABLE>
A hollow tube can handle more stress than a solid bar of the same OD - I know it sounds counter intuitive, but that's statics for you.
I've often wondered that since this is true, we don't see more companies using hollow axles. There's got to be something i am not thinking of...
BUT - the splines are also smaller on the outboard CV joint, AND I'm not sure if the CV joints are of different dimensions - these could contribute to the axles being weaker.
I've often wondered that since this is true, we don't see more companies using hollow axles. There's got to be something i am not thinking of...BUT - the splines are also smaller on the outboard CV joint, AND I'm not sure if the CV joints are of different dimensions - these could contribute to the axles being weaker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag »</TD></TR><TR><TD CLASS="quote">as long as you dont launch that **** hard it fine. </TD></TR></TABLE>
well first to second can be pretty rough on an axle as well...
to the OP:
a lot of guys on here just do the autozone thing with lifetime warranty.
you can get better of course. depends on whats important to you. its obviously cheaper but more of a hassle to use the autozones in the event that they go on you.
to the OP:
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
Reelizmpro
12
Aug 25, 2005 05:17 PM
Ahknodd
Jul 16, 2005 08:53 AM
