88 integra d16twin cam fit into a crx
Old Feb 3, 2007 | 11:12 AM
Rex89's Avatar
Default 88 integra d16twin cam fit into a crx
i was wondering if i could use all the stuff from my single head d16 such as ecu shift linkage
Old Feb 3, 2007 | 11:16 AM
SOHCinWA's Avatar
The motor from an 88-89 (Black Top) will drop right in. No issues at all. Maybe some plugs but thats it.
Old Feb 3, 2007 | 12:09 PM
.Manny.'s Avatar
Touching My Member
Default Re: (SOHCinWA)
get the integra ecu too, but everything else will bolt right up. have fun
Old Feb 3, 2007 | 12:42 PM
Sikocivic's Avatar
Default Re: (90_EF_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">get the integra ecu too, but everything else will bolt right up. have fun</TD></TR></TABLE>
No it won't
The 86-89 Integra motor will fit the 84-87 Civic/CRX but NOT the 88-91.
Old Feb 3, 2007 | 12:44 PM
SOHCinWA's Avatar
If you read the entire post, you will see that I had said that 88-89(Black top) will fit. 86-87(Brown Top) has a different driver side mount
Old Feb 3, 2007 | 12:51 PM
.Manny.'s Avatar
Touching My Member
i meant the same. 88-89. im pretty sure it will
Old Feb 3, 2007 | 02:33 PM
dr_latino999's Avatar
Since when does that bastard motor bolt in?
Also, if your car is newer than the motor the swap is illegal in any inspection requiring states.
Old Feb 3, 2007 | 02:41 PM
Crx Jimmy's Avatar
Default Re: 88 integra d16twin cam fit into a crx (Rex89)
it fits if you have the first gen crx, but you want the 86-87 motor because it has the vacuum advance dizzy and will bolt on(as long as you have the si model), the newer 88-89 motors dont have that and will require a lot of wiring.
Old Feb 3, 2007 | 02:44 PM
djphonics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCinWA &raquo;</TD></TR><TR><TD CLASS="quote">The motor from an 88-89 (Black Top) will drop right in. No issues at all. Maybe some plugs but thats it.</TD></TR></TABLE>
Not true.
This motor will not bolt right into the EF CRX.
Old Feb 3, 2007 | 03:08 PM
SOHCinWA's Avatar
all the ones I have done have never had an issue
Old Feb 3, 2007 | 03:33 PM
89efDUSTY's Avatar
I had d16a1 and swapped back to a6 it bolts right in...and reversible..so yes it will the only difference is the cylinder sensor is on the exhaust cam compared to the a6 where its in the dizzy...but if you do integra ecu it will fit perfectly. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">No it won't
The 86-89 Integra motor will fit the 84-87 Civic/CRX but NOT the 88-91.</TD></TR></TABLE> thats kinda hard to prove seeing i had a 89 CRX with a 89 integra engine, but who knows i must be wrong
Old Feb 3, 2007 | 04:43 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCinWA &raquo;</TD></TR><TR><TD CLASS="quote">If you read the entire post, you will see that I had said that 88-89(Black top) will fit. 86-87(Brown Top) has a different driver side mount</TD></TR></TABLE>
I thought this was for DOHC ZCs..... I've always heard that there was some modification needed to fit the D16A1. But then, I've never done it myself so I'm not exactly sure.
Old Feb 4, 2007 | 12:08 AM
djphonics's Avatar
Default Re: (wiZCo)
Are we talking USDM Integra motors here or what?? All that I've ever heard is that the D16A1 Integra motor has different mounts than the DOHC ZC and will NOT fit in a 2nd gen CRX, and that they will fit into a 1st gen CRX.
Old Feb 4, 2007 | 08:45 AM
Sikocivic's Avatar
It seems like we have to go through this every few months. Do a search, it won't bolt in. Can you make it fit? Yes, but with enough work you can make anything fit.
Old Feb 4, 2007 | 09:10 AM
Deetz's Avatar
Crazy Honda Guy
This thread is kind of dumb as nobody knows what motor this guy is talking about!
If its a usdm dohc d16a1, it will "not" bolt into an EF, and imho would not be would swapping. This engine is a bolt in process for the 84-87 civic/crx's.
The jdm dohc zc blacktop fits as everybody knows. You can reuse all of your old stuff, but need a 88 prelude timing belt for that engine before install
Old Feb 4, 2007 | 09:14 AM
alexsracing's Avatar
Default Re: (Sikocivic)
No it won't
the motor will drop in but you need to get a zc motor mount i have done this swap like 5 times
oh and just use a crx si ecu
jeffknollhuff
24
Dec 20, 2006 05:48 AM
Swipe'd
30
Dec 18, 2006 05:28 PM
nycludekid
Aug 28, 2006 09:21 AM
