:WTB:::Automatic to Manual Transmission swap for '99 Civic EX
manual transmission (96-00 Civic EX S40/P40/P4A B000 preferred)
upper tranny bracket
lower tranny mount
rear tranny mount
pedal assembly
P2P-A12 ECU
clutch master/slave cylilnder
clutch lines and mount
VSS on trans
starter
shifter
shift linkage
all the nuts and bolts
I'm in central Arkansas so if your outside AR I will need shipping also
so include that in the price.
Thanks,
Jason
lower tranny mount
rear tranny mount
pedal assembly
P2P-A12 ECU
VSS on trans
starter
shifter
shift linkage
Thanks,
Jason
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 69NOSAJ »</TD></TR><TR><TD CLASS="quote"> preferred)
lower tranny mount
rear tranny mount
pedal assembly
VSS on trans
starter
Thanks,
Jason</TD></TR></TABLE>i have all the in that list..i took off some of your stuff so be sure to look
lower tranny mount
rear tranny mount
pedal assembly
VSS on trans
starter
Thanks,
I should be getting most of the stuff from 1quickef. The ecu from masterkue.
I'm getting a motor, tranny, and shift linkage from a local guy. the head on the motor is all jacked up supposedly.
I'm also getting an ACT HDG6,
All new belts since I'm sittin at 86k miles.
So that should just about do it.
Also getting ES motor mount inserts all the way around, MFactory short shifter, ****, motor and tranny plugs.
Thanks for all your help H-T guyz!
AznInvasion
Sep 12, 2003 06:19 PM
