Door getting WORSE
Old Feb 3, 2007 | 08:25 AM
lax1089's Avatar
Default Door getting WORSE
this may be insignificant compared to most of the issues on this site but...
i got a 5th gen 4dr EX and the drivers side door is getting harder and harder to open. It isnt a problem with the door handles...I think somehow the part that connects the door to the rest of the car must be getting off track or bending or something.
thanks in advance.
Old Feb 3, 2007 | 09:26 AM
Twixle's Avatar
ate my pixel
Default Re: Door getting WORSE (lax1089)
A little more clarity. You have to pull the handle up hard, or the door is hard to swing open?
Old Feb 3, 2007 | 10:09 AM
bgangsta180's Avatar
Default Re: Door getting WORSE (accord2021)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2021 &raquo;</TD></TR><TR><TD CLASS="quote">A little more clarity. You have to pull the handle up hard, or the door is hard to swing open?</TD></TR></TABLE>
exactly because by what you saying theres no way to help you....not enough info
Old Feb 3, 2007 | 11:48 AM
cityslicker1606's Avatar
spray some wd-40 o0n that sucker!!!!
Old Feb 3, 2007 | 12:06 PM
Twixle's Avatar
ate my pixel
Default Re: Door getting WORSE (cityslicker1606)
and make sure the bolts on your hinges are tight.
Old Feb 3, 2007 | 12:49 PM
Homesickelian's Avatar
Yeah, mine was never really that hard to open but noisy. If you spray some wd40 into the sliding pieces in the middle of the door it might work. The bolts that swing aren't as important, but the piece that actually slides is. Also it isn't to difficult to remove the door so if the wd40 doesn't solve it, take it off and analyze.
Old Feb 3, 2007 | 02:29 PM
lax1089's Avatar
Default Re: Door getting WORSE (Homesickelian)
sorry for the lack of clairty. basically, i lift up on the hande and have to shove it (from the inside) and it feels like it almost drops down a fraction of an inch (as if one of the brackets is bent down or something. im having trouble putting it in words but basically the handles are NOT the problem. If there is a screw or bolt or bracket i can tighten to adjust the doors pathway i think that would fix it. I dont think its a lack of lubricant problem as once i shove the door out it swings open fine
Old Feb 3, 2007 | 03:01 PM
Twixle's Avatar
ate my pixel
two thoughts: 1) check the bolts on the actual hinges, there should be two, one top, one bottom, where the door is connected to the body. 2) check the placement of the latch, on the side where the door opens there is a square U shaped metal piece that the door latches on, there are two large phillips screws that hold it in. You can loosen the screws and adjust the latch in and out a bit to see if that improves things.
Old Feb 3, 2007 | 05:50 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2021 &raquo;</TD></TR><TR><TD CLASS="quote">two thoughts: 1) check the bolts on the actual hinges, there should be two, one top, one bottom, where the door is connected to the body. 2) check the placement of the latch, on the side where the door opens there is a square U shaped metal piece that the door latches on, there are two large phillips screws that hold it in. You can loosen the screws and adjust the latch in and out a bit to see if that improves things. </TD></TR></TABLE>
Or lower it a little bit, I run a pencil around it before getting it loose so you can tell how far it has been moved and which direction.
raphael
Paint and Body
11
Nov 8, 2007 05:36 AM
lalaine17
May 4, 2006 05:18 PM
lanai
Nov 4, 2005 04:36 PM
kniob
Mar 27, 2004 03:06 PM
CB_ejcoupe
Jan 26, 2004 02:35 PM
