1990 honda civic hb
Old Feb 3, 2007 | 07:45 AM
aznboi_2's Avatar
Default 1990 honda civic hb starts but dies
i just bought the car w/ no start situation. I have spark and fuel from replacing the the whole dist. THe car would crank over w/ a couple tries and then immediately shut off...? whats the problem here?
Old Feb 3, 2007 | 08:01 AM
Boosted Chemist's Avatar
Default Re: 1990 honda civic hb starts but dies (aznboi_2)
It is a new dissy? I had the same problem my ignitor was fried, would run for a couple seconds then die.
Old Feb 3, 2007 | 09:24 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: 1990 honda civic hb starts but dies (Boosted Chemist)
you might check your ignition switch..they seem to fail so that your car will crank and sound like its going to start, but not stay on. you can do some simple wiring tests to make sure it is or is not the switch, that way you dont have to buy new parts.
Old Feb 4, 2007 | 08:09 AM
aznboi_2's Avatar
ill check it out today again when i get off from work.
Old Feb 4, 2007 | 01:04 PM
93civiceg6's Avatar
check your fuel filter also your main relay could be an issue as well
Old Feb 6, 2007 | 02:45 PM
aznboi_2's Avatar
Yep it was the fuel filter, guess the gas was frozen in it. The crank over and SNAP gOES the timing belt
civicali
Jan 14, 2019 05:48 AM
MitchHamilton
15
Oct 25, 2016 05:00 AM
jdmrexy90
15
Dec 10, 2011 08:01 PM
85turbottype
Dec 28, 2010 07:58 AM
reese
Jul 30, 2003 02:17 PM
