GSR Swap Problems
Old Feb 2, 2007 | 11:34 PM
krazyblurtzcrx's Avatar
Default GSR Swap Problems
Hey Guys Im trying to finish up this 97 GSR swap into a 90 CRX Si.
Using stock intake manifold and Transmission
I am using a innovative mount kit with hydraulic to cable conversion.
Any Pictures of your GSR or B18 set up would be appreciated...Yes Ive looked at all I could find.
The Cable VSS is too short might be able to reach if there wasnt the tranny T Bracket in the way. Every write up said it would fit.
What Heater hoses do I use?
The hydraulic to Cable transmission bracket is out of wack. I would call innovative but I cant wait till monday, it needs to be out of this house by sunday.Do hook the end of the clutch cable to the actuator just like you would stock on top of the rubberish piece, or do you have to modify it? It looks like it would work if I hooked it up to just the last tad bit of the cable, but that parts too thin anyway.
Because The only way it will fit on is if the fork is fully cocked back ( Yes, even after adjusting the ball-end part that moves the fork)
The actuator for the tranny bracket moves, it unscrews the nut on it. It didnt come with a bushing...so what I have to loctite the SOB?
Modified by krazyblurtzcrx at 9:57 AM 2/3/2007
Old Feb 3, 2007 | 05:25 AM
fin781's Avatar
Default Re: GSR Swap Problems (krazyblurtzcrx)
i cant help u, but that sounds like a killer swap man, best of luck and hope everything goes good
Old Feb 3, 2007 | 05:06 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: GSR Swap Problems (fin781)
i have the same swap same car, you need to remove the metal coolant tube and replace it with a normal hose and it will fit perfect and as for the vss with the stock mani i had to run it over the tps and then down, good luck should be fun mine is
eggsi619
Jun 29, 2009 11:14 AM
m_shake
Apr 13, 2009 09:52 AM
CrazyHB
19
Aug 23, 2004 10:37 AM
kanzenr91si
Oct 1, 2003 12:20 PM
90civichbsi
12
Sep 9, 2002 06:41 PM
