ground controls with kyb gr2's
Old May 17, 2002 | 05:33 PM
urbantrain's Avatar
Default ground controls with kyb gr2's
hey i used the search and found nothing, so no flames. on the ground control's and kyb 2's you have a rubber lining that goes inside the coilover sleeve, on the front they fit perfectly, but on the back they dont fit, anyone know a good solution, it would be really hard to trim these.. it seems like the rubber lining is just too think
Old May 17, 2002 | 05:47 PM
kcxtremeaccord's Avatar
Default Re: ground controls with kyb gr2's (urbantrain)
go to the hardware store and get thinnner ones....
Old May 17, 2002 | 06:39 PM
urbantrain's Avatar
Default Re: ground controls with kyb gr2's (ILiveNextToSabastian)
actually i had some orings that were perfect i just stuffed a **** load of them inside the sleeve, works just as well. if i have any probs with the oring solution ill get some thinner rubber thinggies from the store. thanks man
Old May 17, 2002 | 07:38 PM
smokin rubber's Avatar
my kit came with two large and two small o-rings for each shock/spring.
Old May 17, 2002 | 07:40 PM
urbantrain's Avatar
Default Re: ground controls with kyb gr2's (smokin rubber)
yah, mine came with 8 large orings and 8 small ones *confused* what are all these orings for? i used the 8 large ones, but i have no clue what they want me to do with these smaller ones.. i guess the smaller ones are used for other types of shocks, guess it a universal kit.. but did you have the problem with the 2 rear split sleeves being 2 big?
Old May 17, 2002 | 08:08 PM
yes I only used two of the plastic sleeves, and used all teh extra orings on the sleeveless shocks.
Old May 17, 2002 | 08:21 PM
urbantrain's Avatar
cool.. im glad i made a good decision, i wonder if GC knows their rear sleeves dont fit properly?
Old May 18, 2002 | 12:59 PM
yes they know, thats who told me
ncwlau
Suspension & Brakes
Jul 30, 2008 11:10 AM
grilledcheese33
Suspension & Brakes
Aug 21, 2007 07:36 AM
InTegraLS_2001
May 4, 2004 04:27 PM
igo4bmx
Sep 22, 2003 10:22 AM
Isaac
Apr 19, 2002 09:08 AM
