how do i lower the front of my crx?
Old Feb 2, 2007 | 08:44 PM
cameron_h's Avatar
Default how do i lower the front of my crx?
I need help on lowering the front of my 85' crx. It has shock absorbers in the front with no coil overs. so i need advise on what to do. By the way i lowered the back about 3 inches. Thanks.
Old Feb 2, 2007 | 09:13 PM
Tippyman's Avatar
Default Re: how do i lower the front of my crx? (cameron_h)
So as of now your car looks like it is trying to avoid getting it's motor wet?
Get some better suspension would be my suggestion...
Old Feb 3, 2007 | 08:14 PM
Brick Top's Avatar
Default Re: how do i lower the front of my crx? (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">So as of now your car looks like it is trying to avoid getting it's motor wet?</TD></TR></TABLE>
i gotta see that to believe it.
Old Feb 3, 2007 | 08:19 PM
eda6's Avatar
your car has torsion bars in the front. at the bottom there's a nut you can adjust to lower your ride height. this was one of the 1st mods i did to my AG4 hatch and the nuts were welded afterwards.
Old Feb 3, 2007 | 08:39 PM
cameron_h's Avatar
Default Re: how do i lower the front of my crx? (eda6)
If i adjusted that nut how low can i get it to go? Because i want to get the front to be about as low as the back, which is about 3inches.
Old Feb 3, 2007 | 09:08 PM
eda6's Avatar
it's been 5 years since i've owned that car. i doubt you'll get a 3" drop in the front but i could be wrong.
check out redpepperracing for more info.
Old Feb 3, 2007 | 09:45 PM
cameron_h's Avatar
How much of a drop do you think i will get by adjusting that bolt?
Old Feb 3, 2007 | 10:34 PM
freshly boosted DOHC ZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cameron_h &raquo;</TD></TR><TR><TD CLASS="quote">How much of a drop do you think i will get by adjusting that bolt?</TD></TR></TABLE>
just go try it, it only takes a few minutes
Old Feb 4, 2007 | 06:28 AM
90crxdriver's Avatar
http://www.redpepperracing.com...t-end
doesn't say how low it will go but its a walk threw on how to do it.
Old Feb 4, 2007 | 06:58 AM
jlicrx's Avatar
you will get maybe an inch at the most with the adjusting nut - in order to get more you will need to reposition the splines on the torsion bar in the torque tube - you say you lowered the rear 3" - whenever you lower the rear, the axle moves closer to the driver's side - to correctly reposition the rear axle to the center of the car, you will need an adjustable Panhard bar
crxmadman
Apr 14, 2005 04:59 PM
ghettoracer
23
Jan 4, 2005 06:36 PM
robA90CRXsi
18
Sep 3, 2004 04:35 AM
frznoasys
13
Oct 24, 2002 09:36 PM
knightnam
Sep 14, 2002 08:06 AM
