Which Wire for A/F gauge?
Old May 17, 2002 | 05:07 PM
LOwrestling2001's Avatar
Default Which Wire for A/F gauge?
hi,
which wire is the easiest/most convenient to splice/tap into to wire for the sensor of my A/F ratio gauge?
Old May 17, 2002 | 05:09 PM
Drew M's Avatar
New User
Default Re: Which Wire for A/F gauge? (LOwrestling2001)
https://honda-tech.com/zerothread?id=188311
We are looking for the same info. I am going to try to do mine at the sensor since there is more wire to work with.
Old May 22, 2002 | 02:55 PM
acteg94's Avatar
the easiest way is to jack up u'r car and look for the sensor wires underneath, should be by the catalytic converter .. and there are wires there and its the white one i believe .. just had my mechanic put it in .. and it did look pretty easy ..
Old May 22, 2002 | 03:47 PM
Rory Breaker's Avatar
Default Re: Which Wire for A/F gauge? (acteg94)
I believe mine was a white wire with a blue stripe, FYI.
chrisfromsrq
Jul 30, 2009 09:47 AM
92prelude23
Nov 17, 2008 02:09 PM
ls19integra95
Nov 28, 2007 08:26 PM
qazaq
Apr 28, 2006 09:54 AM
joey1320
Jan 19, 2004 01:47 AM
