obd1 conversion w/2 o2 sensors.....??
Old Feb 2, 2007 | 05:56 PM
vw eater's Avatar
Default obd1 conversion w/2 o2 sensors.....??
well i have a crx that i converted to obd1 every thing done works right.my question is that i have another crx that i wana switch it all over but my other crx has 2 o2 sensors and the othet crx thats obd1 now has only 1 o2 sensor.its a pr3 ecu that has the 2 o2 sensors.
Old Feb 2, 2007 | 08:25 PM
vw eater's Avatar
do i just not hook one up?
Old Feb 2, 2007 | 10:05 PM
oodie's Avatar
Default Re: (vw eater)
you need a 4 wire o2 to be obd1 will not except 1 wire o2
Old Feb 3, 2007 | 05:04 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (oodie)
yeah you need a four wire and you will need a manifold that has the O2 bung right before the cat to ensure proper readings
Old Feb 3, 2007 | 05:50 AM
Boosted Chemist's Avatar
Default Re: (oodie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oodie &raquo;</TD></TR><TR><TD CLASS="quote">you need a 4 wire o2 to be obd1 will not except 1 wire o2</TD></TR></TABLE>
Or you can use just one of your stock ones with a chipped obd1 map with o2 heater disabled
Old Feb 3, 2007 | 04:06 PM
vw eater's Avatar
Default Re: (oodie)
thank u there capt. obvise ...did i not say i have obd1?i know i have to use a 4 wire heated o2 sensor my question is do i just not hook one up?
Old Feb 4, 2007 | 09:31 PM
vw eater's Avatar
ttt
Old Feb 4, 2007 | 09:47 PM
.Manny.'s Avatar
Touching My Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vw eater &raquo;</TD></TR><TR><TD CLASS="quote">thank u there capt. obvise ...did i not say i have obd1?i know i have to use a 4 wire heated o2 sensor my question is do i just not hook one up?</TD></TR></TABLE>
wow, if you are going to be such a dick to fellow members when they actually try to help you...then to you buddy.
btw its obvious
if you are going to stick with the old manifold with two o2 bungs...you have to plug those up and get an o2 bung welded at the end of the header by the cat and hook up your 4 wire sensor there.
if you change to an obd1 manifold, then just use the bung provided for the sensor.
either way, you have to get rid of the sensors you have now.
russianswty
Dec 29, 2006 04:30 PM
robbizza
Aug 15, 2006 10:30 AM
Ruby Civic
Oct 19, 2003 07:51 AM
JBk24crx
Oct 2, 2003 02:26 PM
crx1856
Jun 16, 2003 07:00 PM
