could this cause this?
Old Feb 2, 2007 | 04:55 AM
youknowimwhite's Avatar
Default could this cause this?
recently i tried to change my fuel filter recently but failed to succeed. i got the "out" line off but could not get the "in" off... so reluctantly i put the line back on planning on doing it when i was more recourseful or could pay to have it done.... since then when i go to start my car after it sits for several hours and takes inbetween 10-15 seconds to start up... could my fuel filter be leaking slowly to cause this? is there any cheap fix to get starting up right until i can get the filter changed?
Old Feb 2, 2007 | 05:12 AM
numbnuts22715's Avatar
Default Re: could this cause this? (youknowimwhite)
If its not getting the right amount of fuel then there's no easy fix until you replace the filter.. It's not a hard thing to do.. It took me like 5 minutes... If you can't do it. Take it somewhere, its not good to leak fuel everywhere
Old Feb 2, 2007 | 06:51 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youknowimwhite &raquo;</TD></TR><TR><TD CLASS="quote">could my fuel filter be leaking slowly to cause this? </TD></TR></TABLE>
uhh...do you see fuel anywhere?
It's never a good idea to start a project and not finish it. Get the filter changed so you can eliminate it from the problem should it persist.
Old Feb 2, 2007 | 07:37 AM
Default Re: could this cause this? (SuzukaBlueAP2)
no but every once and awhile i can smell it
Old Feb 2, 2007 | 07:43 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If you smell gas, it's leaking. Whether or not it's causing the starting problem, get that fixed ASAP!!!!
Get a good set of flare nut wrenches, it's not that hard to change the filter.
Usually when I change mine, I don't get the hard line fitting tight enough on the first try. After turning on the fuel pump it will usually dribble a small amount and so I have to put the wrench on it and snug it down a bit more.
jmaz
Honda Civic (2006 - 2015)
Aug 8, 2007 04:30 AM
huge230
Oct 1, 2005 10:59 AM
Rpizzle
Apr 7, 2005 09:37 AM
92blackg2
Feb 28, 2005 04:44 PM
WayneGro
Oct 24, 2003 04:58 AM
