Engine extremely hot...
Old Feb 2, 2007 | 04:41 AM
lax1089's Avatar
Default Engine extremely hot...
just got my car back from the mechanic from a bad accident. said he refilled everything (including coolant) but the engine temp is at full (there isnt a temp warning light or anything but the temp gauge is way higher than normal) is this normal for a car just after it gets worked on? what should i do?
p.s. dont really want to bring it back to the mech...hes really being a dick and would most likely overcharge me.
Old Feb 2, 2007 | 05:01 AM
tsouyporta's Avatar
Default Re: Engine extremely hot... (lax1089)
check the thermostat
Old Feb 2, 2007 | 05:40 AM
H2290's Avatar
Have you checked the coolant overflow for any coolant? Definitely after the engine is warm there should be some in there.
Old Feb 2, 2007 | 10:54 AM
Hawkze_2.3's Avatar
Bleed the cooling system. Air bubbles cause overheating.
Old Feb 2, 2007 | 07:00 PM
Blamm!!'s Avatar
Default Re: Engine extremely hot... (Hawkze_2.3)
A: no the motor should not overheat ever! Q: did they f*ck your car up ?
Old Feb 2, 2007 | 08:30 PM
xjohngox's Avatar
yeah, maybe the thermostat is busted. Try checking it.
Maybe the thermostat got affected or hit when you had your accident.
'Coz if the temp (in the meter) is way too high, your car should have overheated.
Old Feb 2, 2007 | 08:37 PM
sony224422's Avatar
Default Re: Engine extremely hot... (xjohngox)
theres a sensor actually. the thermo could be stuck open or closed. i'd fill the raditor up again and check for leaks anywhere. if you can't see any and aren't losing fluid try to rebleed it.
Old Feb 3, 2007 | 08:18 AM
lax1089's Avatar
Default Re: Engine extremely hot... (sony224422)
well i took it back to them and they flushed out the anti freeze (he said the levels were low despite filling it up a few days prior but that it was normal?). seems fishy to me but its not overheating anymore so i dont know..
Old Feb 3, 2007 | 08:42 AM
importfanatic17's Avatar
That just means that he really didn't fill it up the first time.
Old Feb 3, 2007 | 09:18 AM
sony224422's Avatar
Default Re: Engine extremely hot... (importfanatic17)
no it means he didn't bleed the air out of it. and it even says in the manuals to check it after a few days and add more since there is probably still air in there.
Old Feb 3, 2007 | 11:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">no it means he didn't bleed the air out of it. and it even says in the manuals to check it after a few days and add more since there is probably still air in there.</TD></TR></TABLE>
Or that. That was my problem a while ago...
Old Feb 3, 2007 | 02:17 PM
sony224422's Avatar
haha yeah, i find it like impossible to get all the air out since i can't open my bleeder screw. oh well. i will work its way out, just make sure theres coolant in the overflow
CUTTERSPOOL
Oct 21, 2012 11:05 AM
mherrcat
Mar 20, 2011 03:04 PM
litterbox
Mar 16, 2009 06:50 AM
alexthegrinch
Oct 9, 2008 11:02 PM
superstud
Oct 14, 2004 12:44 PM
