too much oil?/?
Old Feb 1, 2007 | 10:23 PM
teggy182's Avatar
Default 4k limit on d16z6?????
so im new to the sohc game and i have a d16z6 in a cx. i think i may have put about a half of a quart too much oil in it and now it his hitting some limiter at 4k, feels like a fuel cut off. is this related to the engine having too much oil? or is it some other problem. motor has 100k and runs good,(with the exception of the 4k limiter right now) doesnt burn oil or anything like that. TIA
Modified by teggy182 at 10:03 AM 2/2/2007
Old Feb 1, 2007 | 11:00 PM
teggy182's Avatar
Default Re: too much oil?/? (teggy182)
ive also heard this could be the dizzy ******* up my ignition timing. up for any suggestions
Old Feb 2, 2007 | 06:59 AM
teggy182's Avatar
up for ideas
Old Feb 2, 2007 | 07:10 AM
2wheelhunter's Avatar
easy with the language buddy, no i dont beleive adding an extra 1/2 quart of oil will cause you to hit the rev limiter at 4k, i may be mistaken becuase at that rpm oil pressure does rise and oil pressure sensors (i would think) could cause the engine to stall. why dont you just drain some oil or change the oil?
Old Feb 2, 2007 | 07:14 AM
teggy182's Avatar
Default Re: too much oil?/? (2wheelhunter)
just did change it and then i was like **** its at over 4 qt's(i used to throwing 4 in a b18c) so im guessing i overloaded it with oil, but then i let a good half qt. out and its still doing the same thing. and this stall only happens when your givin it more than 70% throttle
Old Feb 2, 2007 | 07:20 AM
sounds like it may be the TPS? mine did that also but if it worked before then i dont know.
Old Feb 2, 2007 | 07:22 AM
teggy182's Avatar
hmm looks like ill be checking the tps.. are they cheap for these motors?
Old Feb 2, 2007 | 08:19 AM
a local junkyard is cheap, ebay is your next best bet. all b-series and d-series TPS are the same
KidAccord
Apr 19, 2013 06:58 PM
EG-SIXV-TEC
11
Dec 13, 2012 02:45 PM
Rok_Stok
Nov 3, 2009 12:18 PM
hotstuffjsn
Mar 22, 2005 01:58 PM
itr501
Oct 23, 2001 02:41 PM
