Last straw with the sol .... so fed up .. help
Old Feb 1, 2007 | 07:24 PM
Hellraver's Avatar
Default Warped b16 ~
I have a b16a3 Del sol.
Its all stock, and I Came into a bit of money now and want to fix it and maybe hook it up a little. First things first I have not been driving it lately because it had a head gasket that was very bad and causing the radiator to overheat but temp gauge in the car showing its fine. So I started with the head gasket oil leak. I got a head gasket from napa and took it to get resurfaced at the best machine shop in NE florida that was recommend to me by alot of people. So I used the tourqe pattern and specs on this site, cleaned the block surface well, took my head out of the wrapping they gave it to me in made sure it was all flat and perfect (and it was, and clean as ****) here are some pics of it
BEFORE:
AFTER:
everything before I put it on ( the head has cardboard under it don't worry =p)
At any rate its still leaking oil from the head gasket, and my radiator overheats if I hit vtec during a trip. I am also getting a 21 and 22 code but I need a new solinoid and I know that already but does not explain the head gasket still leaking. I reused the head bolts. IF I don't give up on the car alltogether, which I'm seriouesly thinking of doing this week, I MIGHT go to honda and buy head bolts and a Honda head gasket but I just wasted all the money doing this job and I'm pretty pissed/dissapointed and about to just sell everything, motor, put a D series in it and sell the car. I have learned alot from my first head job. use honda ******* parts. expletive napa and advanced auto part sloppy ****.
Modified by Hellraver at 6:05 AM 2/2/2007
Old Feb 1, 2007 | 07:37 PM
Hellraver's Avatar
Any advise/help? If not I'm gonna sell it =| I hate spending money and days working and nothing changes.
Old Feb 1, 2007 | 07:40 PM
De_tour's Avatar
Default Re: (Hellraver)
did you resurface your head?
THC07's Avatar
you reused your head bolts?
Old Feb 1, 2007 | 07:48 PM
Hellraver's Avatar
Yes "I got a head gasket from napa and took it to get resurfaced at the best machine shop in NE florida that was recommend to me by alot of people." I took a 45min trip to take my head to get resurfaced.
Yes I reused my head bolts.
Do you think If I got new head bolts and a head gasket from honda it will solve my problems once and for all?
Old Feb 1, 2007 | 08:35 PM
SiYouLater's Avatar
Default Re: Last straw with the sol .... so fed up .. help (Hellraver)
Headbolts are usually a one time use thing.
Old Feb 1, 2007 | 08:40 PM
Eg6hybrid92's Avatar
oem head bolts should not be reused...
Old Feb 1, 2007 | 08:42 PM
Hellraver's Avatar
So if I order some ARP head bolts can I still use the head gasket and just re-torque it down and that correct the problem?
Old Feb 1, 2007 | 08:47 PM
Z3120's Avatar
That's very good, put your resurfaced head on the ground. After all these are not precision parts anyway. Love it when I see engine parts laying on the rough surface.
Old Feb 1, 2007 | 08:51 PM
ridin98civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hellraver &raquo;</TD></TR><TR><TD CLASS="quote">( the head has cardboard under it don't worry =p)</TD></TR></TABLE>
Old Feb 1, 2007 | 08:55 PM
Hellraver's Avatar
yesh I know this. If you look closely at the picture you can also see the tape the machine shop put on the head holding the cardboard under it on.
Old Feb 1, 2007 | 09:01 PM
Hellraver's Avatar
Anyways back to the problem at hand. Will all I have to get is ARP studs to correct my problem here? If so I will be pretty happy ...... Someone that has dealt with a warped head and head gasket leak before could most likely awnser all my questions in one shot.
Old Feb 1, 2007 | 09:32 PM
Hellraver's Avatar
Searching for ARP studs/bolts ..... anyone know a good place with a price under 100$ say around 80-90?
Modified by Hellraver at 6:46 AM 2/2/2007
Old Feb 1, 2007 | 09:47 PM
Tuesday Club's Avatar
no, vtec HB's "should" be the same..... B16, B18c(#).....NOT B18a or B18b
Old Feb 1, 2007 | 09:59 PM
Hellraver's Avatar
Any place you recommend I should order from?
Old Feb 3, 2007 | 12:19 PM
SiYouLater's Avatar
Check modacar.com
Old Feb 3, 2007 | 01:10 PM
DrewMD's Avatar
Davis Photography
Default Re: (SiYouLater)
the only place i would buy gaskets is from honda. nowhere else. unless its a better gasket from a REPUTABLE company.
Old Feb 3, 2007 | 08:56 PM
CRX T-Si's Avatar
Default Re: (DrewMD)
Cometic and OEM honda is the only Headgasket that I would recommend.
You know I would check your block man. Make sure it's nice and flat.
Also don't forget to put the oil ring back on head for the Vtec that is between cylinders #2 & 3.
Be generous on the Moly grease when putting the head studs or head bolts.
If you are going to do the Timing belt by yourself then I would suggest some tie straps to secure the belt to the cam gears.
GL with the repairs.
Shaggibus
Oct 31, 2010 03:23 PM
shady3260
17
Jun 21, 2010 01:23 PM
the_dxB16
Sep 1, 2009 09:10 PM
allmotorb20vtec
Aug 5, 2004 06:56 PM
nread
15
May 11, 2004 02:38 PM
