where do i put the grease?!?
Old Feb 1, 2007 | 07:15 PM
lax1089's Avatar
Default where do i put the grease?!?
i read some of the archived posts on slow power windows and they instruct you to grease the wondow channels. I removed the door panel and applied Lithium Grease (a gooey black substance) in between the two rubber channels with a q-tip and it did nothing if not made it worse. is this the wrong place or wrong stuff or what?
Old Feb 1, 2007 | 07:16 PM
Homesickelian's Avatar
Default Re: where do i put the grease?!? (lax1089)
a lot of the posts recommend silicone. Give that a try instead. If you're using the word right, I don't think gooey would help.
Getting the grease down into the channels inside the door frame is where you really want it.
Make sure you go by other words of advice to. If greasing it up doesnt work, you might just have faulty electronics.
Old Feb 1, 2007 | 07:24 PM
lax1089's Avatar
Default Re: where do i put the grease?!? (Homesickelian)
so did i mess it up now that there is lithium grease all in the tracks : (
Old Feb 1, 2007 | 07:30 PM
I'm not familiar with the stuff but here's one description:
Lubricates & Protects All Metal Parts
and I'm not sure how metalic the rails are so eh.. I doubt it ruined it but give silicone a try, that works on plastic and rubber.
Old Feb 1, 2007 | 09:11 PM
iam7head's Avatar
honda sells a lude, use that.
the problem with the "other" stuff is taht they will dry after a while, if they do coked up, the track will be jammed and the window will not go down with the speed they used to.
if you are dealing with those dirt and dried up grease, use the carb cleaner to remove the goo
confidence
Feb 19, 2011 07:10 PM
r33dm0n3y
Feb 18, 2009 04:35 PM
93FastLs
Apr 29, 2004 10:26 PM
DC2 to AP2
Mar 10, 2004 07:00 AM
gsr.sedan
Jun 7, 2001 01:36 AM
