91 si braking problem
Old Feb 1, 2007 | 06:00 PM
viciousef9's Avatar
Default 91 si braking problem
recently i have notice that when i brake i am almost to the floor. its weird. i have new brake and new master cylinder. a friend of mine tells me that i might need to blee the brakes again. any suggestion please help.
Old Feb 1, 2007 | 06:17 PM
dr_latino999's Avatar
Default Re: 91 si braking problem (viciousef9)
Probably do need to bleed again if you aren't leaking.
Old Feb 1, 2007 | 06:46 PM
coot_er's Avatar
Default Re: 91 si braking problem (dr_latino999)
did you bench bleed the MC?
Old Feb 1, 2007 | 07:41 PM
JesseCRX's Avatar
Replace the master cylinder again and re-bleed your lines. If the problem persists, replace the calipers. My calipers had bad seals in them and once I got new ones everything was fine.
Old Feb 3, 2007 | 01:49 AM
viciousef9's Avatar
no im not leaking. its just when im brakin im almost to the floor. i have the rear disc brake conversion. i want to know what would be some good calipers if need for the front and rear
jdmswappedcivic
Suspension & Brakes
Apr 18, 2010 09:30 PM
HRPfg2
11
Jul 12, 2009 08:30 PM
Eighty-Nyne
Apr 21, 2009 07:30 AM
faster_thn_hell
Jun 13, 2007 11:57 AM
MikeySpec
Jul 18, 2004 04:03 PM
