I NEED HELP !! No power gauge cluster is dead ?!!?
Old Feb 1, 2007 | 05:40 PM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default I NEED HELP !! No power gauge cluster is dead ?!!?
So i was coming home yesterday i was on the freeway then all of a sudden when i turned my blinker on to switch lanes my cluster died out, rpm needle went to 0 speedo went to 0, Gas Needle went to the bottom, Temp went down, and clock all died, so i pulled out to a rest area and my right corner light was COMPLETELY GONE !! bulb, connector, corner. Headlights still work WHEW !!
Well ok after all the shock & disbelief, now how do i get everything to work again ?
Old Feb 1, 2007 | 05:45 PM
mc's Avatar
mc
Default Re: I NEED HELP !! No power gauge cluster is dead ?!!? (Evolution-93-Ex)
fix the corner light and harness then check all your fuses
Old Feb 1, 2007 | 05:48 PM
BlueIntegraBoy's Avatar
What do you mean your corner light was completely gone?
Old Feb 1, 2007 | 05:55 PM
Default Re: I NEED HELP !! No power gauge cluster is dead ?!!? (BlueIntegraBoy)
I got a new connector not sure about the bulb though, I checked some of the fuses they seemed fine which fuse should i mainly check at ? The corner light flew off im guess while i was on the freeway it might have been loose
Old Feb 1, 2007 | 06:47 PM
Check backup or instrument cluster fuses.
Old Feb 2, 2007 | 12:04 AM
Mr.Eg6's Avatar
x2 whaat you mean your corner is gone and it might be a fuse or a short somewhere
Old Feb 2, 2007 | 12:17 AM
Pr0ject93hb's Avatar
Default Re: (SexyEgSix)
same this kinda happened to my homies ej on the way to vegas. he blew a tire and the ripped treat knocked out his fake none good fitting vision corner which in turn ripped all wiring from the passenger corner (then proceeded to bouce off my car since i was behind him) and i guess the wires grounded. he last EVERYTHING inside the car. we check all the fuses...i wanna say it was his back up fuse...just check everything very carefully...and check under the hood too. some fuses say one thing and do another...at least with my car. gl
Old Feb 2, 2007 | 02:31 PM
Default Re: (Pr0ject93hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0ject93hb &raquo;</TD></TR><TR><TD CLASS="quote">same this kinda happened to my homies ej on the way to vegas. he blew a tire and the ripped treat knocked out his fake none good fitting vision corner which in turn ripped all wiring from the passenger corner (then proceeded to bouce off my car since i was behind him) and i guess the wires grounded. he last EVERYTHING inside the car. we check all the fuses...i wanna say it was his back up fuse...just check everything very carefully...and check under the hood too. some fuses say one thing and do another...at least with my car. gl</TD></TR></TABLE>
Yea you understand thanks so much bro i got it fixed now everything is back to normal (except im missing a driver side corner light haha)
GroundZer0 336
Jun 26, 2010 07:02 PM
ltran82
Nov 1, 2007 12:58 PM
EH-3
17
Mar 15, 2006 03:23 PM
Slow_Boy
Aug 24, 2004 12:45 PM
nxstrikerxn
Jul 9, 2004 08:00 PM
