clunk when letting off gas in first ger...motor mounts?
Old Feb 1, 2007 | 01:58 PM
SmobbinSi's Avatar
Default clunk when letting off gas in first gear...motor mounts?
I think my motor mount(s) have finally went out. What is the best value for the money? Should I replace all 4 or just the one that is worn out/cracked? (stock original b16a in a 1999 Civic Si)
Thanks for your help in advance.
Old Feb 1, 2007 | 02:10 PM
nicko360's Avatar
* B A N N E D *
Default Re: clunk when letting off gas in first gear...motor mounts? (SmobbinSi)
might be a loose lug nut, I had the same prob
Old Feb 1, 2007 | 02:11 PM
nicko360's Avatar
* B A N N E D *
does it click when you accelerate? and is it louder when you go around turns accelerating or decellerating?
Old Feb 1, 2007 | 03:09 PM
Mistermark's Avatar
to test to see if its your mounts, their are a few ways, start with a visual inspection, then have someone hold the brake and give the gas a shot, if its a mount, ull see alot of movement on the mount
IMO if its just one mount, just replace the one, unless u wanna upgrade and do all 4
Nova_Dust
Mar 14, 2008 04:40 PM
1SlowB16EF
11
May 11, 2006 07:35 PM
nevin
Oct 15, 2003 08:30 AM
Old Skool
Feb 22, 2003 12:17 PM
