Which bearing is right ?
hi , The spindle studs broke, Two of them so i have to press the bearing out in order to get myself new one in. Now my question is that many people have told me that i would have to buy new bearing .Are the integra's 90-93 and crx si the same ?
I assume you are talking about the wheel studs. I had problems with some crappy lug nuts that kept freezing on my studs in the past. Instead of taking the whole spindal off you can grind a little of one side of the head of the stud you can fit a new one in there. You shouldn't have much of a problem taking the old ones out as they are shorter now and should be able to radius out of there....if you do cut them closer to the hub and they should come out with a hammer. To get the new ones in get yourself a spacer or a bunch of washers and to pull the stud into the hub.
This will save you the trouble of pulling everything off and pressing every thing in and out.
How do you not know where your knuckle is from? In case you have a valid explanation for not knowing which one you have, just look at the size of your brakes (usually a dead giveaway). ~10.3" Integra, smaller = CRX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creator »</TD></TR><TR><TD CLASS="quote">I assume you are talking about the wheel studs. I had problems with some crappy lug nuts that kept freezing on my studs in the past. Instead of taking the whole spindal off you can grind a little of one side of the head of the stud you can fit a new one in there. You shouldn't have much of a problem taking the old ones out as they are shorter now and should be able to radius out of there....if you do cut them closer to the hub and they should come out with a hammer. To get the new ones in get yourself a spacer or a bunch of washers and to pull the stud into the hub.
This will save you the trouble of pulling everything off and pressing every thing in and out.</TD></TR></TABLE>
I've always had a little trouble when my car was over 70 to 80 mph... after showing the whle assemble out of the car to a mechanic he grabber the hub showed me the little play on it. he told me it wasnt normal that it shoudlnt have any play whatsoever... so i guess the bearings are bad anyways.. I thought about cutting it closer to the hub to get them out but i'm having a hard time imagining geting the new ones in. A sketch would really be nice
Thanks for he input anyway
.Thanks for he input anyway
l <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">How do you not know where your knuckle is from? In case you have a valid explanation for not knowing which one you have, just look at the size of your brakes (usually a dead giveaway). ~10.3" Integra, smaller = CRX.</TD></TR></TABLE> Ihave a 10.3" rotors ... aren't the Si's 10.3 thr front ? and won't the Si hub take 10.3" ??
Cut the black part off. You might need to angle back towards the head of the stud just a little. I wouldn't bother with this process if your going to do the bearing anyways.
If you do the bering make sure to press the hub out of the bering and remove the snap ring out of the spindal to press the bearing out. Use lube to press everything back together. It is common for the outside part of the bering to get stuck on the hub. Use a cut off wheel to cut this off it doesn't matter much if you nick up the hub a LITTLE as that part doesn't move.
No the Si's are 9.5", the EX Sedans got 10.3s though. Now you have to determine if you have EX knuckles or DA knuckles, because they don't use the same bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">No the Si's are 9.5", the EX Sedans got 10.3s though. Now you have to determine if you have EX knuckles or DA knuckles, because they don't use the same bearing.</TD></TR></TABLE> should i be looking for a specific imprint that differenciates one from the other ???
THanks for all the info guys
TheSauceSpot
22
Jun 4, 2009 02:52 AM
GroundZer0 336
Sep 19, 2006 03:22 PM
Driven
Apr 29, 2005 12:50 PM
