stock turbo elbows...
Old Feb 1, 2007 | 10:51 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default stock turbo elbows...what are they made of? welding wise
anyone know what the stock turbo elbows on say...the ford 2.3 turbos and the 80's dodge 2.2/2.5 TEo4H/TB03 turbos are made of??
looks like cast iron to me but I see a lot of people cutting them at the flange and welding steel downpipes to them.
how exactly do you weld steel to iron lol??
Old Feb 2, 2007 | 07:05 AM
fuhsm1's Avatar
Default Re: stock turbo elbows...what are they made of? welding wise (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">how exactly do you weld steel to iron lol??</TD></TR></TABLE>
I'm not sure about your first question, it may be cast iron. You can weld steel to cast iron, no it's not the easiest thing to do "properly", but for making at-home downpipes like you mentioned, it is definitely doable.
I used to own a 99 Civic Si, and I built and installed a turbo kit with it. I took a Mitsu 4G63 turbo exhaust manifold and cut off the factory flange that bolts to the head. I also took a factory B18 exhaust manifold and did the same. I mig welded the B-series head flange to the mitsu manifold with mild steel wire, and whala, had a Honda turbo manifold.
Was it the "best" way to do it, no. But, it was cheap ($25 total), did not leak, allowed me to run the Eclipse 14B turbo and o2 housing, and fit great. Would it last forever, I don't know. But, it held up for the year or so that it was on there before I took it all off and sold the car.
dejavu247
Mar 29, 2008 07:51 PM
kierkegag
Jun 25, 2006 04:45 PM
O16581724 5 2 5
Jan 17, 2006 08:06 AM
b16av8killer2
Oct 17, 2005 10:56 AM
jcmcnugent
Welding / Fabrication
14
Jan 9, 2005 07:54 PM
