siR spindles and integra rears?
Old Feb 1, 2007 | 07:07 AM
usdm_ED7's Avatar
Default siR spindles and integra rears?
hey whats up guys i just had a quick question. i was wondering which rotors and pads i should be getting for the siR spindles. are they the same as an integra? also what pads should i get, the ones for a hatchback or for a integra? any help is appreciated! thanks
Old Feb 1, 2007 | 08:40 AM
Boosted Chemist's Avatar
Default Re: siR spindles and integra rears? (usdm_ED7)
Integra or 90-91 civic ex rotors and pads.
Old Feb 1, 2007 | 09:30 AM
FIGARILA's Avatar
how did you get around the different tie rod hole issue.????
If you ever replace the bearings please let us know what bearing you used.
Old Feb 1, 2007 | 09:36 AM
Default Re: siR spindles and integra rears? (FIGARILA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FIGARILA &raquo;</TD></TR><TR><TD CLASS="quote">how did you get around the different tie rod hole issue.????
If you ever replace the bearings please let us know what bearing you used.</TD></TR></TABLE>
Tie rod, since the sir tie rod holes are 1" in comparrision to the si. I just cut an inch off and chased the threads with the proper die. Works fine
Old Feb 1, 2007 | 09:39 AM
FIGARILA's Avatar
Default Re: siR spindles and integra rears? (Boosted Chemist)
Tie rod, since the sir tie rod holes are 1" in comparrision to the si. I just cut an inch off and chased the threads with the proper die. Works fine </TD></TR></TABLE>
bangin'
Old Feb 1, 2007 | 03:14 PM
usdm_ED7's Avatar
can i use any 90 and up integra rotors? which pads do i use...integras also? thanks again guys...
firejackal
11
Apr 8, 2014 03:56 PM
virginia_dude
29
Dec 20, 2007 05:31 PM
Boosted Chemist
May 2, 2005 01:56 AM
