4pad clutch
Old Feb 1, 2007 | 05:53 AM
efking1985's Avatar
Default 4pad clutch
can a 4pad or 6pad clutch be used for daily driving and drag racing?
Old Feb 1, 2007 | 06:12 AM
dr_latino999's Avatar
Default Re: 4pad clutch (efking1985)
Are you really going to be throwing that much power out of a SOHC to need them? I say match the clutch to your torque levels, not to how cool it sounds when you tell people you have a 4-Puck.
Old Feb 1, 2007 | 06:20 AM
efking1985's Avatar
Default Re: 4pad clutch (dr_latino999)
i just need the disc for the 86-89 accord street but cant find it
Old Feb 1, 2007 | 06:37 AM
Do you have a manufacturer preference? I have the Exedy, ACT, and Clutchmasters catalogs in front of me and I'll be glad to throw a part number your way after I get back from class.
Old Feb 1, 2007 | 06:39 AM
efking1985's Avatar
it dont matter stage1 or stage 2
Old Feb 1, 2007 | 11:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't matter, one or two levels in torque capacity will do.</TD></TR></TABLE> Fixed Stages are something the marketing people stole from NFS and GT to make their products sound extra special. You buy clutches buy capacity, not by an unspecified term.
All of the following will be the part numbers for just the clutch disk.
APPLICATION - 1986 - 1989 Accord, 212mm, 7/8" 21 Splines
ACT - Torque Capacities when used with Heavy Duty Pressure Plate
Modified Street Disk - 2000103 - 200ft/lbs
Performance Street Disk - 3000103 - 200ft/lbs
*6-Pad Spring Disk - 6212111 - 256ft/lbs
*4-Pad Spring Disk - 4212111 - 256ft/lbs
* Not Recommended for street use
Centerforce
** CF I - CF806908
** Dual Friction - DF518005
** Clutch and Pressure plate
Competition Clutch
** Gravity - 8008-2400 - 40-50% Increase
Exedy
N/A
Old Feb 1, 2007 | 01:44 PM
allblacksrt4's Avatar
bump
Old Feb 1, 2007 | 01:45 PM
Default Re: (allblacksrt4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allblacksrt4 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE> For what reason?
commando150
Jun 13, 2008 07:03 PM
hpi247
Jul 7, 2007 07:11 AM
team 15
Apr 23, 2007 02:55 PM
91crxturbo
Dec 16, 2006 07:17 PM
BoostedEgHatchFl
Oct 26, 2005 07:31 PM
