Headers Dented!! !!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yodastien »</TD></TR><TR><TD CLASS="quote">What you should do is raise your car back up. you do not need any more than a 1.5 inch drop on any car. More than that you start doing more harm than good</TD></TR></TABLE>
OR if you must have the dumped look then you could try wrapping some of that header wrap around the area that is scraping other then that your f**ked
Unless of cause you go 4-2-1 header lol…..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaper2022 »</TD></TR><TR><TD CLASS="quote">raise your car... too much drop can be detrimental to handling.</TD></TR></TABLE>
no keep it slammed...
just drive careful and weld a 1/4" plate on the bottom.
my F swap was very low too, i know what your going through
If you don't like the other options. Make your own header using using box steel to try and give you more ground clearance nah just raise your car up or live with the damage to the header.oh yeah buy the way hitting the header like that will crack the welds and cause a leak
thx guys for the advices
but iam goin to keep my car dump and try to weld on a skid plate or steel on the bottom of my header
.. and no iam not goin to raise my car.. if i do i hav to raise it pretty high or it wont make a difference.. !
it won't do you no good if you weld it to the header. need to weld it somewhere sturdy off the header so that when it hits the floor its not pushing up on the header and putting stress on it.
Yep, if you just weld a big piece of metal to the header, all you're going to do is break your header. Headers aren't designed to be nailed, welding a plate to the bottom just transfers the force to another part of the header.
You should attach the skid plate to the frame or somewhere equally as sturdy, overwise all you're doing is wasting money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThaSi »</TD></TR><TR><TD CLASS="quote">thx guys for the advices
.. and no iam not goin to raise my car.. if i do i hav to raise it pretty high or it wont make a difference.. ! </TD></TR></TABLE>
enjoy your shitty ride quality
.. and no iam not goin to raise my car.. if i do i hav to raise it pretty high or it wont make a difference.. ! </TD></TR></TABLE>enjoy your shitty ride quality
gapsook
Mar 24, 2004 08:01 PM
