Boosted ITR.. Need some Mani. Suggestions...
Before all you guy's freak out about this being a boost thread here, it's an ITR, and this forum is the only one i trust with opinion's from my experiance's. So any help would be great...
I was just wondering if there was any big differance with the HP gain's on a Top Mount vs. Ram Horn? I've seen gain's on the ram horn, but only on a stock GSR with 10 psi. and those #'s where around 50-75whp. Havn't seen any on a Top Mount though.
I'm guessing there would be more HP gain's from the Top Mount because of the longer runner, but I've heard they spool smaller turbo's a little slower then a Ram Horn. I'm Just wondering because I'm running a T3/T67 and I love the spool but I really want to go equal length Mani. If at all possible, where in the Powerband would these gains be?
Anyone have any experiance with this? Or any dyno #'s? I've have a Stock Block @ 10 psi (B18C5) and a mildly built head (crower turbo cam's, port match, 3 angle, springs & retainers). I'm just wondering which would be better w/ 3'' DP..
Thanks for the help..
depends on what you want. if you want ac ramhorn is the way to go, although i think they make top mounts ac compatible now. 3" down pipe can go with either one, however you can use a 4" down pipe with the top mount. i wouldn't worry about more hp, because with the 67 you will have more than enough power to spin the wheels in all gears.
There is a thread where full-race compares both manifolds i just cant find it now.
Topmount will produce a little more but im a ***** and cant live without p/s
You have a big turbo for a stock engine, what exactly r your goals for the car?
melovesboost
Mar 28, 2007 07:41 PM
BoOsTeD_R_728
Feb 1, 2007 10:26 AM
Spooled1.6L
Apr 18, 2003 01:37 PM
