Car NOT Starting...please HELP
94 accord with h22a swap..couple months ago it was running strong but Iacv was bad so parked it for a month or so waiting for iacv to come in, was purchased from one of the member here..anyways, iacv came in, installed it put everything back together, now the car wont fire up..its cranking but firing...what could it be? fuel is on, spark, all fuses are good...anyone suggestions would be appreciated..please keep it clean as im a little noob on hondas....im a vw enthusiasts..thanks
I think he said hes getting fuel and spark, so the car was running before with a messed up IACV and nothing has changed other than a new IACV, and it won't start? How long did you try and crank it? It might be flooded after not starting after so many tries. I would check the plugs to see if its flooded and If the battery is running low jump it and crank it for a little while, don't keep turning the ignition on and off between cranks because it primes the fuel pump/injectors. As long as it has fuel, spark, air, and the correct timing it should start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POET »</TD></TR><TR><TD CLASS="quote">NGK</TD></TR></TABLE>
yah i think i know that but number?
Firing order is, 1 - 3 - 4 - 2 One being nearest timing belt,
NGK Platinum ZFR6F-11
Standard plugs.
Check all your grounds with a meter, make sure they were good after the swap & replacing iacv if disturbed.
Standard plugs.
wtfbrok3n
Jul 19, 2009 09:45 PM
LsVtakYO
Jan 18, 2006 01:15 PM
