Cold Air Intake Question
I have a cold air intake with a by pass valve on my B16a. now my concern is that it is close to the wheel and I dont have the splash guard or the rubber lining that goes by the fender. I am concerned that when I drive, although I have the bypass valve some water will still enter my engine because it is being hit upwards by the wheel. Can the Bypass valve take care of this or am I just being too paranoid?
Yeah I too want to know if california rain will send any water up with a cold air without the plastic guard being on. I've heard it's only when there are serious puddles that you should worry but just to clarify...
I have a cold air, and a bypass on my DC2, i just took off the bypass, and put the filter on where the bypass goes (which makes it a short ram) when i know it's going to rain. I run the cold when it's not going to rain for a little while. hope that helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by car_crazy_2007 »</TD></TR><TR><TD CLASS="quote">I have a cold air, and a bypass on my DC2, i just took off the bypass, and put the filter on where the bypass goes (which makes it a short ram) when i know it's going to rain. I run the cold when it's not going to rain for a little while. hope that helps
Thats exactly what i do and works fine...only takes a couple of minutes to swap out
</TD></TR></TABLE>Thats exactly what i do and works fine...only takes a couple of minutes to swap out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK4_Coupe »</TD></TR><TR><TD CLASS="quote">I have a cold air intake with a by pass valve on my B16a. now my concern is that it is close to the wheel and I dont have the splash guard or the rubber lining that goes by the fender. I am concerned that when I drive, although I have the bypass valve some water will still enter my engine because it is being hit upwards by the wheel. Can the Bypass valve take care of this or am I just being too paranoid?</TD></TR></TABLE>
If your engine takes in a little water, it won't even be close to what is needed to hydro-lock it...that's the whole purpose of the bypass valve. So yes you'll be safe and yes you will probably suck up a slight amount of water but it's the large amounts that cause problems.
