help with running b16
alright well i have obd2 b16 putting it in to a 93 dx obd1.. im using the stock harness... i got the motor in and it starts up and runs but boggs sounds like it it cammed bad... well when i give it gas it will bogg... i checked the timing and it right and checked the spark and fuel injector... i have a plug that cames up kinda by the timing belt and was wondering if that would be the top dead center sensor... and its not plugged up and i dont have a plug for it on my stock harness... i have a plug that will go into it but i dont know where to wire it in to the stock harness.. and if you guy have any other ideas... also i tried to use the cel plug to check for codes but when i looked on the write up it said it was a grey plug with like black red and white wires... but the only plug i could find was green with a brown and blue wires in it so.. but let me know if you know what to do with the plug on the side of the block...
cloviskilla
Jan 14, 2011 07:40 PM
chinese acrobat
May 17, 2009 08:52 AM
Apex i ITR
Apr 15, 2003 04:21 PM
