skip shifting
Old May 17, 2002 | 12:04 PM
d8168055's Avatar
Default skip shifting
I've been doing this alot latie, reasons dunno why, but is it bad? i've been shifting from 2nd->5th or 3rd->5th, just for city driving... is the power transition bad for the clutch/flywheel?
Old May 17, 2002 | 12:05 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: skip shifting (d8168055)
No it's fine. I do it all the time.
CPR's Avatar
CPR
I tried shifting from 2nd->5th one time...Holy grindage
Old May 17, 2002 | 12:10 PM
nc-rsx-s's Avatar
New User
Fine as long as you don't lug the engine when you get into 4th/5th, meaning below 1000rpms or so (approx)
reefer_bob's Avatar
Default Re: skip shifting (CPR)
I do it all the time too... I never grid. Gotta make sure not to lug the engine. My favorites are 1 - 4, and 3 - 5...
Old May 17, 2002 | 12:11 PM
01ITR#700's Avatar
I skip 3rd all the time for city driving. I would assume it's fine as long as your not redlining 2nd then powershifting into 4th or 5th.
M
Old May 17, 2002 | 12:14 PM
d8168055's Avatar
Default Re: skip shifting (01ITR#700)
cool, thanks folks...
Old May 17, 2002 | 12:20 PM
01PYITR's Avatar
once in a while i do 1st to 3rd then 3rd to 5th and 5th to 2nd on downshift.
Old May 17, 2002 | 12:31 PM
BrandonClaps's Avatar
New User
Default Re: skip shifting (01PYITR)
just make sure you give your syncros enough time to catch up with eachother so there is no grindage. The syncros are going from one gear to the next, not skip one. It's fine as long as you let them catch up, when downshifting, rev match
Old May 17, 2002 | 01:06 PM
skafia's Avatar
25 Year Member
What about shifting without the clutch? Not at high RPMs... but around 5-6K or so... it just goes in so smoothly without the clutch... is this bad?
Old May 17, 2002 | 01:16 PM
Junglist's Avatar
Default Re: skip shifting (skafia)
are you serious!!!!????? that takes some ***** to try out. I've thought about it, but ...
Old May 17, 2002 | 01:17 PM
skafia's Avatar
25 Year Member
Default Re: skip shifting (Junglist)
No, accelerate normall to about 5,000 RPM, and slowly shift from 3rd to 4th (w/o clutch). The gears go RIGHT in like butter.
Old May 17, 2002 | 01:28 PM
Willard's Avatar
If you can do it well... got for it... it does cause extra wear on the syncros...
Will
-who drives his 220,000+ mile Volvo sometimes w/o a clutch when his leg gets tyred
Old May 17, 2002 | 01:33 PM
skafia's Avatar
25 Year Member
Default Re: skip shifting (Willard)
Well, there is no grindage, no noise, nothing! It just slips right in as if the clutch were in... Certain RPMS allow this... and I heard it has NO effect on the motor/tranny/clutch.
Old May 17, 2002 | 02:22 PM
reefer_bob's Avatar
Shifting w/o the clutch is real tough on your synchros I thought... You can also downshit with out the clutch if you really want. You just have to pull it out of gear, rev the motor, and then push gently... it works!!!
Old May 17, 2002 | 02:25 PM
01PYITR's Avatar
Default Re: skip shifting (reefer_bob)
ON my old SR5 I only used the clutch to start moving and never while drivin used the clutch, you can feel when its ready to slide in and out of gears just takes pratice but never force it ! and that car now has 200,000 miles!
Old May 17, 2002 | 02:48 PM
SoCal ITR's Avatar
Default Re: skip shifting (newt2)
Old May 18, 2002 | 05:01 AM
EagleR's Avatar
Default Re: skip shifting (SoCal ITR)
I can row up or down through the gears w/o clutch. Started doin it at 5k, 29k now....3rds syncro is shot but thats a different story or hard drivin as to how that got smoked
Old May 18, 2002 | 11:28 AM
Tommy_Gunns's Avatar
shift slower so the rpms aren't as high when you engage and the grinding should not appear
That being said, I don't skip gears anymore cause I have a nasty habit of shifting fast (not drag racing fast but fairly fast).
[Modified by Tommy_Gunns, 2:29 PM 5/18/2002]
Old May 18, 2002 | 11:36 AM
TypeR 599's Avatar
Default Re: skip shifting (Tommy_Gunns)
this weird, say if you're in 3rd at 5k rpms, you can just pull the shifter out of 3rd and into 4th without stepping on the clutch?
Old May 18, 2002 | 11:56 AM
Razor's Avatar
yes i've seen people do that with their manual trannies and its ok as long as there is no grinding. you can do this much easier on dump trucks and tractors trailers that have no synchros(which requires you to double clutch).
Old May 18, 2002 | 12:01 PM
slash00R's Avatar
New User
Default Re: skip shifting (Razor)
Yes, if you pull it out of gear right after getting off the gas, it will come out very smoothly because the tran and half shaft are spinning at relatively the same speed. Remember that synchros aren't required when shifting into neutral .. you only need the clutch to disengage the engine/flywheel/halfshaft from the transmission, or when you're up-shifting, which allows smoother (and slower) engagement of the gears with the help of the synchros
cliff notes : yes
Old May 18, 2002 | 12:06 PM
Larkin W.'s Avatar
Default Re: skip shifting (slash00R)
I bet this is even more fun on the Type R's but downshifting from 3,500 rpms in 4th to second is soooooooo much fun in the Si
Old May 18, 2002 | 12:19 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
if you learn to double clutch you can shift between any gears you wishes to with in the mechanical rpm range of the gear with out any problems. for example cruising along 30 mph in 5th and need to drop it in to first? no problem if you do it right. or, if you understand the rpm relationship between the gears, clutchless shifting is cooler. although it's a bit hard on the car if you do it wrong.
http://www.g-speed.com/pbh/double-clutch.html
[Modified by frank@b16a.com, 1:21 PM 5/18/2002]
Old May 18, 2002 | 03:00 PM
Ideal R's Avatar
New User
as far as i know, you should not skip gear while up-shifting. It is not very good to the tran.. For example, the 4th gear sychronizer are not design to match the rpm of 2-4 shift. It is design to match the rpm of 3-4 shift.
of course, everyone knows power shift (shift without clutch) do nothing except bad things to ur tran.
