**car not starting**HELP
94 accord with h22a swap..couple months ago it was running strong but Iacv was bad so parked it for a month or so waiting for iacv to come in, was purchased from one of the member here..anyways, iacv came in, installed it put everything back together, now the car wont fire up..its cranking but firing...what could it be? fuel is on, spark, all fuses are good...anyone suggestions would be appreciated..please keep it clean as im a little noob on hondas....im a vw enthusiasts..thanks
Is your battery run down? If the engine is not being rotated fast enough, it will not start.
I assume that all your electrical and ignition connection are tight and all the hoses are in place and all the gaskets are good and finally the distributor has not been accidentally turned.
try checking the battery. If you didn't use the car for a month or so, the battery may be weak.
**Batteries charge whenever the car is in use.
If your battery is weak, change it or have it charged. Your car should start after that.
1,3,4,2 is firing order. ZFR6FIX-11 is the part number for iridium spark plugs. Or you could just call up the parts store, I'm sure they'd know, if you don't want iridium plugs.
W O T
May 8, 2007 10:36 AM
